nsmiller Posted August 8, 2016 Author Share Posted August 8, 2016 Is there any significant difference between chain lube and chain wax as far as how they work. Chain wax seems like it may not fling as easy but will turn my chain white. Just asking since I have minimal experience. Link to comment Share on other sites More sharing options...
Premium Member fddriver2 Posted August 8, 2016 Premium Member Share Posted August 8, 2016 +1 on the grease ninja...... "It doesn't matter who walks in, you know the joke is still the same" Ft. Lauderdale, Florida. USA Link to comment Share on other sites More sharing options...
redfjniner Posted August 8, 2016 Share Posted August 8, 2016 WD-40 is mainly Kerosene, with some added ingredients so it works just as good as Kerosene for cleaning, with a little benefit for lubing, but not ment to be a chain lube for high speed chains as found on motorcycles. I am using on my current chain, Liquid Wrench Chain Lube. I didn't like the Chain Wax, others do but I didn't think it gave me the chain life I expected. Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 114,000 m (Replaced engine at 106K) Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted August 9, 2016 Premium Member Share Posted August 9, 2016 I've never been a fan of WD40, although I can't tell you why. If I had nothing else I might use it in a pinch, but I typically use Maxima Racing Oils Synthetic Chain Guard Crystal Clear Chain Lube (now that's a mouth full) It seems to do a good job, and and doesn't make a big mess Link to comment Share on other sites More sharing options...
redfjniner Posted August 9, 2016 Share Posted August 9, 2016 I've never been a fan of WD40, although I can't tell you why. If I had nothing else I might use it in a pinch, but I typically use Maxima Racing Oils Synthetic Chain Guard Crystal Clear Chain Lube (now that's a mouth full) It seems to do a good job, and and doesn't make a big mess David: What do you use to clean the chain? Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 114,000 m (Replaced engine at 106K) Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted August 9, 2016 Premium Member Share Posted August 9, 2016 Kerosene Link to comment Share on other sites More sharing options...
nsmiller Posted August 16, 2016 Author Share Posted August 16, 2016 Additionally, when you spray on the lube, spray it on the top of the lower chain run. (i.e. the "inside" of the chain). That will cause the centrifugal force to push the lube through the chain before getting flung off.And a great little tool for spraying the lube of your choice (I still have a few cans of the old formula DuPont Teflon Multilube which I consider the best) is the Grease Ninja. http://www.greaseninja.com/ Put mine in a freezer bag along with a rag to wipe the chain down with, and you're good to go...lube my chain every 1000 miles whether it needs it or not. What size grease ninja is appropriate for the FJ-09? The GN428/520 or the GN525/530? Link to comment Share on other sites More sharing options...
bruceintucson Posted August 16, 2016 Share Posted August 16, 2016 And a great little tool for spraying the lube of your choice (I still have a few cans of the old formula DuPont Teflon Multilube which I consider the best) is the Grease Ninja. http://www.greaseninja.com/ Put mine in a freezer bag along with a rag to wipe the chain down with, and you're good to go...lube my chain every 1000 miles whether it needs it or not. What size grease ninja is appropriate for the FJ-09? The GN428/520 or the GN525/530?GN525/530. Refers to chain size & FJ has a 525. Link to comment Share on other sites More sharing options...
