caferacer Posted August 22, 2016 Share Posted August 22, 2016 Rear tire picked up a nail on the Interstate a couple days ago, I was prepared with a tire plug kit in my saddlebags, but foolishly didn't think to pack a pump to inflate the tire after repair. Felt kinda goofy as I had to wait for a manual air pump to be brought to me :-[ . With no tire gauge, my best effort at getting the tire as close to road-ready as I could guess-timate turned out to be only 24 psi. For those of you who travel prepared to repair/plug a tubeless tire roadside, what is in your kit? Especially interested in reasons for manual v. electric air pump. Link to comment Share on other sites More sharing options...
desertfjr Posted August 22, 2016 Share Posted August 22, 2016 This kit... Genuine Innovations With three of these cartridges... 45 Gram Link to comment Share on other sites More sharing options...
Premium Member peporter Posted August 22, 2016 Premium Member Share Posted August 22, 2016 Here's what I carry for trips. A bit spendy, but it got the job done on the Dalton Highway during a thunder storm. Didn't take long at all either. Brought the tire up to full pressure in no time. http://www.pashnitmoto.com/cycle-pump-p/cp-combo.htm Link to comment Share on other sites More sharing options...
Premium Member wessie Posted August 22, 2016 Premium Member Share Posted August 22, 2016 Can of Wynns Tyrefix or similar http://www.wynns.uk.com/Product.aspx?p=43001&g=GRP_CONS_WORK and a small compressor from Stop n Go http://www.mandp.co.uk/index.php/default/stop-and-go-mini-air-compressor.html - use the croc clips on the battery as the power socket fuse is too low This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
duhs10 Posted August 23, 2016 Share Posted August 23, 2016 I have this compressor... http://www.slime.com/us/products/auto/inflators/12v-auto-/power-sport.php its about $30 USD on amazon and a plug kit similar to what you used. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
mhevezi Posted August 23, 2016 Share Posted August 23, 2016 I went with a kit that included a couple of CO2 cartridges. It should get me to a gas station in a pinch. Link to comment Share on other sites More sharing options...
djmotosport Posted August 23, 2016 Share Posted August 23, 2016 Update: Bad advice - the JACO pump blew the fuse on the 12v. Don't make the same mistake I did! I always carry a tire repair kit, and this electric inflato -JACO Premium Digital Tire Inflator - Portable Air Compressor Pump, 100 PSI, available on Amazon for $50. I don't carry it for short trips close to home, but any time I'm out on a longer run I do. It's small enough to fit in a tank bag, lightweight, and works great. Link to comment Share on other sites More sharing options...
joese Posted August 23, 2016 Share Posted August 23, 2016 I always carry a tire repair kit, and this electric inflato - JACO Premium Digital Tire Inflator - Portable Air Compressor Pump, 100 PSI, available on Amazon for $50. I don't carry it for short trips close to home, but any time I'm out on a longer run I do. It's small enough to fit in a tank bag, lightweight, and works great. You can power it off the 12v plug on the bike. Does this not blow the fuse? I heard you need to clip on to the battery for these small pumps. Link to comment Share on other sites More sharing options...
brando Posted August 23, 2016 Share Posted August 23, 2016 I always carry a tire repair kit, and this electric inflato - JACO Premium Digital Tire Inflator - Portable Air Compressor Pump, 100 PSI, available on Amazon for $50. I don't carry it for short trips close to home, but any time I'm out on a longer run I do. It's small enough to fit in a tank bag, lightweight, and works great. You can power it off the 12v plug on the bike. Does this not blow the fuse? I heard you need to clip on to the battery for these small pumps.it blew both of my fuses when i tried to use mine...... Link to comment Share on other sites More sharing options...
jsp Posted August 23, 2016 Share Posted August 23, 2016 These small air compressors use 10 amps or more. I believe the 12v plug has a 3 or 5 amp fuse. john Link to comment Share on other sites More sharing options...
duhs10 Posted August 23, 2016 Share Posted August 23, 2016 Does this not blow the fuse? I heard you need to clip on to the battery for these small pumps.it blew both of my fuses when i tried to use mine...... Definitely hook it directly to the battery. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted August 24, 2016 Premium Member Share Posted August 24, 2016 After riding bicycles for ages, I definitely recommend the CO2 Gas cartridges, just make sure you have enough to inflate the tire to get you to a gas station Link to comment Share on other sites More sharing options...
desertfjr Posted August 24, 2016 Share Posted August 24, 2016 Yep, just as easy with a motorcycle tire. I picked up a screw on the way back from Sturgis last year. Pulled the offending screw, plugged the tire and hit it with 3 CO2 cartridges and was on my way. Stopped at the next station to get the air pressure back to spec and ran the tire until it was replaced this year. Link to comment Share on other sites More sharing options...
nickest85 Posted August 28, 2016 Share Posted August 28, 2016 my brother and I just got done doing riding and camping up the coast and his valve stem was loose after checking the pressure and we didn't have a way to tighten it. I suggest having a couple valve stems and the tool to replace/tighten them. we were lucky enough to find a tire repair shop and they got us back on the road in no time. Link to comment Share on other sites More sharing options...
zimbob Posted September 5, 2016 Share Posted September 5, 2016 I have a tire plug kit with a co2 inflate devise with I think three cartridges. Link to comment Share on other sites More sharing options...
