ryan Posted September 16, 2016 Share Posted September 16, 2016 just wondering if this is normal recently while getting onto the nj ternpike i noticed when going next to the concrete barriers that while on the throttle any amount i heard a chain noise, off the throttle coasting no chain noise at all chain is lubed, gets lubed once a week, as i put on close to 100miles a day on it thanks Link to comment Share on other sites More sharing options...
caferacer Posted September 16, 2016 Share Posted September 16, 2016 Yes it's normal, if it bothers you, the stock chain slack spec is too tight according to many, I agree, and loosened slack to 1" (eyeballed the same as the rest of the bikes I've ever ridden). Link to comment Share on other sites More sharing options...
ryan Posted September 16, 2016 Author Share Posted September 16, 2016 i loosened it about 1" as well right after i bought it last year it to me too seemed way to tight also i did notice some inside of rear sprocket wear only on the inside side tho Link to comment Share on other sites More sharing options...
Premium Member britelitebob Posted September 16, 2016 Premium Member Share Posted September 16, 2016 i loosened it about 1" as well right after i bought it last year it to me too seemed way to tight also i did notice some inside of rear sprocket wear only on the inside side tho Sprocket wear on just one side means your rear wheel is out of alignment, could be off just a hair but I'd check it out. BLB Link to comment Share on other sites More sharing options...
racer Posted September 17, 2016 Share Posted September 17, 2016 How many miles on your chain? May be time for a new one. Link to comment Share on other sites More sharing options...
ryan Posted September 18, 2016 Author Share Posted September 18, 2016 just under 9k on it Link to comment Share on other sites More sharing options...
