Premium Member ULEWZ Posted February 4, 2017 Premium Member Share Posted February 4, 2017 Did you just order the Tenere switch from a Yamaha parts retailer? I have a 2015 lined up to buy if it's still avail when I return from a 3 week trip and this is a mod I definitely want to do. Ride your bike down to So. Cal. I will install it for you easy peasy. A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted February 4, 2017 Supporting Member Share Posted February 4, 2017 I had purchased the recommended tools: jewelers screwdriver set which I cleaned prior to use, heat gun and hook/pick set. Compiling with instructions I also cleaned the area where the velcro strips stick. Also remember that the harness goes under the tank mount. Thanks for the tips. I have everything needed except the heat gun. Do the pins come out of the connectors fairly easily, or should I get some sort of pin extractor? ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
desertfjr Posted February 4, 2017 Share Posted February 4, 2017 Pin comes out of the ECU harness very easy after you release the catch for the pins. Make sure you reseat the MCCruise pin all the way. The catch should re-engage with relative ease. The only other connecter to disassemble is the TPS. The jewelers screwdriver or small pick will allow you to depress the tab holding them in and the drop out easy. If you need a mount for your LED and don't want it in the switch gear let me know. I have a few LED mounts left like the one I made for my install. My CC Install Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted February 4, 2017 Supporting Member Share Posted February 4, 2017 Thanks so much for the tips, the link to your install is fantastic! ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
root Posted February 5, 2017 Share Posted February 5, 2017 After I placed the order, they sent me the installation .pdf manual, I read through it and I have to say it looks a bit intimidating. In actual hands-on practice, how was the install? The mechanical aspect is a non-issue, but removing wires/pins from electrical harness plugs has me worried. My bike is only a few weeks old and I don't want to break anything or make it inoperable. To those who have installed the MCCruise, any hints/tips or special tools required to make it easier? Thanks in advance. The install was time consuming for me. Set aside a day to do it and just take it one step at a time. I'm an IT guy that's not too mechanically inclined. The most intimidating part was taking the bike down that far, but each step on its own was easy. Keep track of all your parts and follow the instructions and you'll be fine. Link to comment Share on other sites More sharing options...
root Posted February 5, 2017 Share Posted February 5, 2017 After I placed the order, they sent me the installation .pdf manual, I read through it and I have to say it looks a bit intimidating. In actual hands-on practice, how was the install? The mechanical aspect is a non-issue, but removing wires/pins from electrical harness plugs has me worried. My bike is only a few weeks old and I don't want to break anything or make it inoperable. To those who have installed the MCCruise, any hints/tips or special tools required to make it easier? Thanks in advance. Oh, and congrats. That and the mirror extenders are my favorite mods I've done so far. Link to comment Share on other sites More sharing options...
Scuba Posted February 5, 2017 Share Posted February 5, 2017 After I placed the order, they sent me the installation .pdf manual, I read through it and I have to say it looks a bit intimidating. In actual hands-on practice, how was the install? The mechanical aspect is a non-issue, but removing wires/pins from electrical harness plugs has me worried. My bike is only a few weeks old and I don't want to break anything or make it inoperable. To those who have installed the MCCruise, any hints/tips or special tools required to make it easier? Thanks in advance. The install was time consuming for me. Set aside a day to do it and just take it one step at a time. I'm an IT guy that's not too mechanically inclined. The most intimidating part was taking the bike down that far, but each step on its own was easy. Keep track of all your parts and follow the instructions and you'll be fine.You sound like me so thanks for the reassurance. Joe2014 Super Tenere ES Link to comment Share on other sites More sharing options...
Premium Member peporter Posted February 6, 2017 Premium Member Share Posted February 6, 2017 The install was time consuming for me. Set aside a day to do it and just take it one step at a time. I'm an IT guy that's not too mechanically inclined. The most intimidating part was taking the bike down that far, but each step on its own was easy. Keep track of all your parts and follow the instructions and you'll be fine.You sound like me so thanks for the reassurance. I did the install and had about a month break right in the middle. Came right back and picked up where I left off and completed the install with no problems. You will recieve a couple of special tools that make the install easy. My complaint to the guys down under was that it wasn't real clear where in the install the tools went, but I figured it out. If logic prevails, you won't have a problem. Link to comment Share on other sites More sharing options...
Premium Member chadman Posted February 6, 2017 Premium Member Share Posted February 6, 2017 Did you just order the Tenere switch from a Yamaha parts retailer? I have a 2015 lined up to buy if it's still avail when I return from a 3 week trip and this is a mod I definitely want to do. Ride your bike down to So. Cal. I will install it for you easy peasy. Can I take you up on this? I'm local in Valencia. Will pull the trigger on the MC Cruise "sometime" this year. Chadman http://www.twistypedia.comThe roster: '79 Honda XL 125 '83, Honda Ascot VT500, '84 Kawasaki GPz 550, '83 Honda VF700, '86 Kawasaki Ninja 600, '87 Kawasaki Ninja 1000, '84 Suzuki GSX-R 750, '96 Honda CBR600F, '98 Kawasaki ZX-7R, '85 Kawasaki Ninja 600, '01 Suzuki GSX-R 750, '16 Yamaha FJ-09, '15 Yamaha FJR1300ES, KTM 1290 Super Duke GT Link to comment Share on other sites More sharing options...
Premium Member ULEWZ Posted February 6, 2017 Premium Member Share Posted February 6, 2017 Ride your bike down to So. Cal. I will install it for you easy peasy. Can I take you up on this? I'm local in Valencia. Will pull the trigger on the MC Cruise "sometime" this year.Sure. Send me the instructions when you get them, as the de-pining is new to what I did twice. A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
kimmie Posted February 6, 2017 Share Posted February 6, 2017 I ordered my MC Cruise Control yesterday from Tony here is Oz. Looking forward to receiving it!! Kimmie......the lady who likes to take little detours Link to comment Share on other sites More sharing options...
kimmie Posted February 9, 2017 Share Posted February 9, 2017 AND........my MC Cruise Control kit arrived today WOOT WOOT Just have to wait for hubby to do the installation.......I do assist (in case you are wondering). Kimmie......the lady who likes to take little detours Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted February 9, 2017 Supporting Member Share Posted February 9, 2017 AND........my MC Cruise Control kit arrived today WOOT WOOT Just have to wait for hubby to do the installation.......I do assist (in case you are wondering). I just checked tracking on mine and both the CC unit and Tenere switch gear will be delivered tomorrow! I am excited to get this project going as well. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
cranky Posted February 10, 2017 Share Posted February 10, 2017 Did you just order the Tenere switch from a Yamaha parts retailer? I have a 2015 lined up to buy if it's still avail when I return from a 3 week trip and this is a mod I definitely want to do. Ride your bike down to So. Cal. I will install it for you easy peasy. Where in So. Cal are you? Link to comment Share on other sites More sharing options...
xcsp Posted February 11, 2017 Share Posted February 11, 2017 Is there a reason one would choose the Super Tenere switch housing over the one used on an FJR? Link to comment Share on other sites More sharing options...
