Cruizin Posted October 18, 2016 Share Posted October 18, 2016 With winter coming I thought I'd share this $4.99 battery tender. I paid full price a couple years ago for one of these and it works great, used it last two winters and the batteries were in tip top shape in the spring. Motocentric Battery Tender/charger Yamaha FZ-10 ForumYamaha FZ-07 ForumYamaha Ténéré 700 Forum Click here to go "ad free" become a supporting member and gain of bunch of forum perks! Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted October 18, 2016 Premium Member Share Posted October 18, 2016 and type in code "fs-thx-153" for free shipping Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted October 18, 2016 Premium Member Share Posted October 18, 2016 Whereas it may work OK, optimum charing is achieved for most motorcycle batteries at 1.25 amps at 14.45 volts, so this charger is providing only half the prescribed amperage Link to comment Share on other sites More sharing options...
Cruizin Posted October 18, 2016 Author Share Posted October 18, 2016 Yet somehow my battery is in tip top shape. I just bought five more for christmas presents for some friends. Yamaha FZ-10 ForumYamaha FZ-07 ForumYamaha Ténéré 700 Forum Click here to go "ad free" become a supporting member and gain of bunch of forum perks! Link to comment Share on other sites More sharing options...
Premium Member wessie Posted October 18, 2016 Premium Member Share Posted October 18, 2016 Whereas it may work OK, optimum charing is achieved for most motorcycle batteries at 1.25 amps at 14.45 volts, so this charger is providing only half the prescribed amperageI suggest you read http://jgdarden.com/batteryfaq/carfaq9.htm#equalization and the rest of http://www.batteryfaq.org/ Ideal battery charging is a combination of current limited charging, constant voltage charging and fixed current charging - that website has some typical charging algorithms used by smart chargers. Here's one for an AGM battery as fitted to the FJ09 You will note that only 2 hours of the 16 hour cycle is at a fixed current. The figures, using 10A as the current limit are for a heavy duty car charger. A 750mA charger is fine for motorcycle batteries - it would struggle to charge a large battery from a diesel car or petrol V8 as it will probably go into float mode before it has added enough electrons. If you look at the Ctek range of chargers, probably the best chargers for the home & professional user, they start with a 800mA charger for motorcycles. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
zachd Posted October 19, 2016 Share Posted October 19, 2016 Thanks Cruizin...picked one up. The free shipping coupon code definitely helped the purchase too, thanks David! Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted October 24, 2016 Premium Member Share Posted October 24, 2016 Whereas it may work OK, optimum charing is achieved for most motorcycle batteries at 1.25 amps at 14.45 volts, so this charger is providing only half the prescribed amperageI suggest you read http://jgdarden.com/batteryfaq/carfaq9.htm#equalization and the rest of http://www.batteryfaq.org/ Ideal battery charging is a combination of current limited charging, constant voltage charging and fixed current charging - that website has some typical charging algorithms used by smart chargers. Here's one for an AGM battery as fitted to the FJ09 You will note that only 2 hours of the 16 hour cycle is at a fixed current. The figures, using 10A as the current limit are for a heavy duty car charger. A 750mA charger is fine for motorcycle batteries - it would struggle to charge a large battery from a diesel car or petrol V8 as it will probably go into float mode before it has added enough electrons. If you look at the Ctek range of chargers, probably the best chargers for the home & professional user, they start with a 800mA charger for motorcycles. Yes I agree and understand the science of battery charging. What I was trying to convey is that optimum motorcycle battery charging typically requires a minimum of 1.25 amps which the charger in question cannot provide (it's rated at .75 amps). Also, I prefer brand name chargers made by Deltran (http://www.batterytender.com/Frequently-Asked-Questions/#answer4) and Tecmate (http://tecmate.com/products/optimate5/) Link to comment Share on other sites More sharing options...
megroovy Posted October 25, 2016 Share Posted October 25, 2016 personally I just stick a small solar panel on the roof of the garage. does the job for me. Link to comment Share on other sites More sharing options...
oldfart Posted October 25, 2016 Share Posted October 25, 2016 I'm not sure whether I enjoyed this page about the science of battery charging (Not to be confused with tending) more than I enjoyed the two pages about whether the FJ-09 is best fueled on the side stand or center stand. Hmmmmm..... Link to comment Share on other sites More sharing options...
Premium Member wessie Posted October 25, 2016 Premium Member Share Posted October 25, 2016 I suggest you read http://jgdarden.com/batteryfaq/carfaq9.htm#equalization and the rest of http://www.batteryfaq.org/ Ideal battery charging is a combination of current limited charging, constant voltage charging and fixed current charging - that website has some typical charging algorithms used by smart chargers. Here's one for an AGM battery as fitted to the FJ09 You will note that only 2 hours of the 16 hour cycle is at a fixed current. The figures, using 10A as the current limit are for a heavy duty car charger. A 750mA charger is fine for motorcycle batteries - it would struggle to charge a large battery from a diesel car or petrol V8 as it will probably go into float mode before it has added enough electrons. If you look at the Ctek range of chargers, probably the best chargers for the home & professional user, they start with a 800mA charger for motorcycles. Yes I agree and understand the science of battery charging. What I was trying to convey is that optimum motorcycle battery charging typically requires a minimum of 1.25 amps which the charger in question cannot provide (it's rated at .75 amps). Also, I prefer brand name chargers made by Deltran (http://www.batterytender.com/Frequently-Asked-Questions/#answer4) and Tecmate (http://tecmate.com/products/optimate5/) I have corrected the cocked up formatting in your post. I don't suppose anyone buying a $5 charger worries about optimum charging. All they want is for some electrons from the national grid to be transferred into their battery and the will sleep just the same if they trickle in at 750mA or romp in at 1250mA. The number of electrons stored is finite so after a few hours, current inflow will be 0mA. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
