carey Posted November 8, 2016 Share Posted November 8, 2016 I purchased a set of LED turn signals for my bike and had a question about installation. The Panel that the turn signal mounts to is held on by 3 screws. After removing the panel, there's another panel layer on the inside held on by 2 screws and several toothed retainer washers that look like this; Has anybody removed these retainer washers without destroying them? Any tips? Link to comment Share on other sites More sharing options...
duhs10 Posted November 8, 2016 Share Posted November 8, 2016 I used a small flat head screwdriver to pry them off being careful not to bend them too bad... To replace them, I used a small socket (like 7mm or 8mm socket) to press them back on the plastic stem evenly. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
carey Posted November 8, 2016 Author Share Posted November 8, 2016 Thanks. I wasn't confident that I could remove them without damaging them, so I googled the Yamaha part number. I found them for $0.54 each and ordered a few spares just in case. Link to comment Share on other sites More sharing options...
redfjniner Posted November 8, 2016 Share Posted November 8, 2016 ....Has anybody removed these retainer washers without destroying them? Any tips?Use a utility knife to work them up around the perimeter (thin flat blade screwdriver will help too). You can reuse them. I used a 4mm or 5mm (size that fits snug onto the studs) socket to press them back on.Ditto. After crash, I was able to reuse a number of these, lock washers. I also bought three bags of six to make sure I had enough and now have a few left over. Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 114,000 m (Replaced engine at 106K) Link to comment Share on other sites More sharing options...
Supporting Member 1moreroad Posted November 8, 2016 Supporting Member Share Posted November 8, 2016 I wondered the same thing: http://fj-09.org/thread/4261/apart-floating-front-panel Link to comment Share on other sites More sharing options...
