Under Bar Chinese Steering Damper / Mount Kit Review
Purchased the under bar Steering Damper and mounting kit. The kit came with the incorrect link arm. Not long enough. Had to mount the tower pin support 180 degrees out and bush the Damper up with some washers. A little improvising on the tower pin height adjustment as well. Otherwise went in easy. Works very well. Took it out on a favorite desert road that has lots of linear grooves that before had unsettled the bike at speed, especially on the gas and leaned over. Bike would get really twitchy. Now, very composed.
Have a link so others can check it out and buy it?
Here is what I've found on this.
Photos are kinda screwed up, but there is one of it installed. Looks sanitary. would like all the alloy in black however, but nothing a can of rattle flat black can't solve.
http://www.ebay.com/itm/Steering-Damper-With-Mounting-Bracket-For-Yamaha-MT-09-Tracer-2015/131878184016?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D38530%26meid%3D6ca08f8e95074c8eaa92f9b1837966bf%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D252379271419
