sunshine Posted December 12, 2016 Share Posted December 12, 2016 Is there some secret magic trick to getting this thing to work? I've tried 3 different plugs in there and none of them have worked at all. Link to comment Share on other sites More sharing options...
zachd Posted December 12, 2016 Share Posted December 12, 2016 Have you checked the fuse to make sure it's not blown? I use two different plugs made by Anker and Amazon, and have zero issues with either. Link to comment Share on other sites More sharing options...
sunshine Posted December 12, 2016 Author Share Posted December 12, 2016 Have you checked the fuse to make sure it's not blown? I use two different plugs made by Anker and Amazon, and have zero issues with either. I didn't even think to check the fuses to be honest, since the bike is brand new. Will report back in the am. Link to comment Share on other sites More sharing options...
docsimple Posted December 12, 2016 Share Posted December 12, 2016 i believe the fuses on the accessory port is 2 amps. I blow them everytime I plug anything with more draw than a cell phone... 2015 Red FJ 09 2013 WR250R - little boy blue - sold 2012 DL650 V Strom - sold 2007 FZ6 - sold 1986 FJ600 - sold Link to comment Share on other sites More sharing options...
Premium Member Brick Posted December 12, 2016 Premium Member Share Posted December 12, 2016 You do know that you have to have the key on for the outlet to work... right!! It's a switched circuit. Brick 2015 Yamaha FJ-09 "Red Molly" 2014 Yamaha Super Tenere' ES 1999 Suzuki SV650 Link to comment Share on other sites More sharing options...
sunshine Posted December 17, 2016 Author Share Posted December 17, 2016 i believe the fuses on the accessory port is 2 amps. I blow them everytime I plug anything with more draw than a cell phone...Yes, both of the aux fuses are 2 amps. I think the first thing I tried using in there was an air pump, which probably draws way more than 2 amps but I visually inspected both of the aux plugs (8 and 10 iirc) and didn't see any breaks. There's an extra two amp plug in the box that I swapped in to one of them just for good measure but no luck getting the outlet to work. Link to comment Share on other sites More sharing options...
sunshine Posted December 17, 2016 Author Share Posted December 17, 2016 You do know that you have to have the key on for the outlet to work... right!! It's a switched circuit. Lol, ty brick. I tried every conceivable combination of on/off/lock/hazard/idle/highway speed and never once saw it draw any power to my phone. Link to comment Share on other sites More sharing options...
jo1000 Posted December 30, 2016 Share Posted December 30, 2016 i believe the fuses on the accessory port is 2 amps. I blow them everytime I plug anything with more draw than a cell phone...Yes, both of the aux fuses are 2 amps. I think the first thing I tried using in there was an air pump, which probably draws way more than 2 amps but I visually inspected both of the aux plugs (8 and 10 iirc) and didn't see any breaks. There's an extra two amp plug in the box that I swapped in to one of them just for good measure but no luck getting the outlet to work.I did the same thing tried the air pump and it indeed blow the fuse Link to comment Share on other sites More sharing options...
carey Posted December 31, 2016 Share Posted December 31, 2016 My Garmin 550 GPS supposedly draws less than 2A. I have a power cord set up with a BMW/Powerlet connector and another power cord with a traditional cigarette plug. Every time I use the Powerlet plug with a Powerlet to cigarette plug adapter it blows the fuse. I even tried a 5A fuse with the same result. When I use the power cord with a cigarette plug and 2A fuse, it works fine. Link to comment Share on other sites More sharing options...
carey Posted December 31, 2016 Share Posted December 31, 2016 My Garmin 550 GPS supposedly draws less than 2A. I have a power cord set up with a BMW/Powerlet connector and another power cord with a traditional cigarette plug. Every time I use the Powerlet plug with a Powerlet to cigarette plug adapter it blows the fuse. I even tried a 5A fuse with the same result. When I use the power cord with a cigarette plug and 2A fuse, it works fine. ...could it be the adapter itself...I mean, something other than the GPS is blowing the 5A fuse.I'm sure it's the adapter, but I have no way to verify. Anyway, I solved the problem by mounting a Powerlet socket on the left side, where the OEM socket was originally, and moved the OEM socket to the right side. Link to comment Share on other sites More sharing options...
Premium Member wessie Posted December 31, 2016 Premium Member Share Posted December 31, 2016 My Garmin 550 GPS supposedly draws less than 2A. I have a power cord set up with a BMW/Powerlet connector and another power cord with a traditional cigarette plug. Every time I use the Powerlet plug with a Powerlet to cigarette plug adapter it blows the fuse. I even tried a 5A fuse with the same result. When I use the power cord with a cigarette plug and 2A fuse, it works fine. either the adapter or powerlet lead has a short circuit (or only when they are joined) easy to check with a multimeter set to continuity test. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
