koth442 Posted March 11, 2017 Share Posted March 11, 2017 I call BS. The dealer couldn't figure it out so they gave you something plausible. I still think its the head stem bearings. '15 FJ09 Link to comment Share on other sites More sharing options...
catrike16 Posted March 11, 2017 Author Share Posted March 11, 2017 How many people are having this issue? If it is the floating rotors then wouldn't we all be experiencing it? All of the time? The thing is I didn't notice any knocking at first, it started around 400 miles, the first time it happened I got off and checked that something hadn't fallen off or cracked. It seems to be related to both braking and compression of the forks, it is also intermittent so again if it was the rotors I would expect it, if not all the time, then certainly more often. Anyway, that said I'm going straight to the horses mouth first thing on Monday. Calling Yamaha direct and I'll ask them. If they say it shouldn't be clunking, it'll be back in the dealer 5 mins after the phone goes down. Link to comment Share on other sites More sharing options...
eeetea Posted March 11, 2017 Share Posted March 11, 2017 They are floating disks, but they shouldn't make clunk when you brake. Its most like to be the pad moving in the caliper. Are your springs and pins seated properly...they can clunk if they're not. Have you had a second opinion from another garage? I'm not saying your dealer is, but I've met some pretty dire mechanics in my time...my BMW main dealer was always leaving bolts lose...or missing (three seperate occasions on my GS) Honda SS50, Kawasaki Z200, Honda 400/4, Yamaha TDM900, Yamaha XT660Z Tenere, KTM 990 Adventure, BMW R1200GS, Mr Stevens, and my favourite of all: Yamaha MT-09 Tracer...a bit like FJ-09 only properly named :¬P Link to comment Share on other sites More sharing options...
dbeau Posted June 15, 2017 Share Posted June 15, 2017 I'm inclined to believe the noise is in fact the rotors and here's why... I too noticed the noise but it was intermittent and couldn't always replicate it until today. Engine off, I rolled forward slightly and hit the front brake "clunk". Rolled backwards slightly and hit the front brake "clunk". If you do this in either direction twice you don't hear it as far as my limited testing went. Edit: Or the pads like others have suggested but I definitely think its the brakes Link to comment Share on other sites More sharing options...
josh Posted June 16, 2017 Share Posted June 16, 2017 +1 on floating disc thought Link to comment Share on other sites More sharing options...
balu Posted August 9, 2018 Share Posted August 9, 2018 Is this knocking also when passing through holes? I have a new Tracer GT and I have knocking from front when I passong through holes. Link to comment Share on other sites More sharing options...
gerdawg Posted August 16, 2018 Share Posted August 16, 2018 On my FJR I had the same clinking and even replaced my steering head bearings with tapered. It still clinked when going over pot holes or jolting the bike around. I'm pretty comfortable that it's the floating rotors causing the noise. 2019 Yamaha Tracer 900 GT Link to comment Share on other sites More sharing options...
bugie Posted September 13, 2018 Share Posted September 13, 2018 Is this knocking also when passing through holes? I have a new Tracer GT and I have knocking from front when I passong through holes. My GT does this too. It usually does it when cold and only at low speed which makes me believe it is only whilst the components are cold Link to comment Share on other sites More sharing options...
