pmason718 Posted August 20, 2018 Share Posted August 20, 2018 If you order from here you're looking at about $110 for this mod https://www.yamahapartshouse.com/oemparts/p/yamaha/2bs-83310-10-00/front-flasher-light-assy-1 https://www.customled.com/products/yamaha-oem-turn-signal-connectors-3-wire Link to comment Share on other sites More sharing options...
roadwarrior Posted August 21, 2018 Share Posted August 21, 2018 Do you need two blinker relays for the front or just one? Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted August 22, 2018 Supporting Member Share Posted August 22, 2018 Do you need two blinker relays for the front or just one? Only one relay for the entire bike. I replaced all four signals with the Super Tenere LED lights, and used the suggested relay to get the flasher speed back to normal. https://tstindustries.com/TST-LED-Flasher-Relay-Gen2.html Link to comment Share on other sites More sharing options...
roadwarrior Posted August 22, 2018 Share Posted August 22, 2018 Great thanks. I see how it works now. That is pretty slick that you can control the blinker speed through the relay rather having to use a in-line resistor. Is the FJ/Tracer relay by the battery then? Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted August 22, 2018 Supporting Member Share Posted August 22, 2018 Is the FJ/Tracer relay by the battery then? Exactly. It’s under the rider’s portion of the seat, on the right side near the battery. Link to comment Share on other sites More sharing options...
raggededge Posted September 4, 2018 Share Posted September 4, 2018 I just wanted to update this. I cut out the resistors because I too figured they were for load balancing. After some time the blinkers have turned very orange and close to red. I expect at some point they will burn out and I’ll have to do this over again. Oh well lesson learned. Link to comment Share on other sites More sharing options...
roadwarrior Posted September 16, 2018 Share Posted September 16, 2018 Installed my front Super Tenere (ST) LED blinkers today. A big thank you do Stevesweetz for providing the pictures and write up on post #1. Weird that on the Tracer GT the right side blinker wires are different colors from the left side. For instance, what is red on the left side is blue on the left. Why wouldn't they be the same? Just to be difficult I suppose. Anyway, the most challenging part was getting the base of the ST blinker back on the plastic side panel. Really took a lot of screw driver prying and cajoling. The blinkers look and fit great and the black finish is a much nicer match to the rest of the bike then the grey finish of the stock pumpkins. For the back I used Motorydynamics integrated tail light. The TST relay worked great controlling both front and back blinkers. Plus, I could eliminate the tail lights resistors which are bulky and from what I understand, put off a fair amount of heat. 1 Link to comment Share on other sites More sharing options...
northsouth Posted July 9, 2020 Share Posted July 9, 2020 Just finished this mod too. Everything worked perfectly the first time. Looks great and was well worth it. Thanks very much for the detailed tutorial! 1 Link to comment Share on other sites More sharing options...
