tripleb Posted August 4, 2017 Share Posted August 4, 2017 Hello all, I've had my FJ for about 4 months now, and have managed to log about 1,800 miles to date. Unfortunately I've started noticing issues with my down shifting starting at around 3rd gear. Seems to be quite rough and non consistent. I would shift and hit a blank spot where nothing happened, gear indicator on handlebar would read zero, I then would have to pull in the clutch and firmly downshift again. Other times shifting from 3rd to 2nd, and 2nd to first would be quite erratic. Definitely not smooth by any nature. Has anyone else noticed this issue as well? I hope someone is able to shed some helpful info my way. Thank you in advance guys . Link to comment Share on other sites More sharing options...
suitedsevens Posted August 4, 2017 Share Posted August 4, 2017 I am having the exact same issue. I'm right behind you at about 1500 miles. It usually happens to me when I'm pulling up to a stop light and down shifting from 5th to first. My "blank spot" is usually in between 4th and 3rd but it does seem to move around once in a while. It only seems to happen about once every few days so I kinda just forget about it but it's quite unnerving. '17 electric white fj - oem heated grips - oem hard side bags - heated corbin saddle - mra touring screen - motodynamic tail light - baja designs led turn signals - yoshimura full exhaust/fender eliminator - k-tech razor r rear shock/front fork kit - evotech radiator guard - mt-09 adventure pegs - pazzo shorty levers - stainless bar end weights '19 Husky fe501 - cut off a few things and fixed the fueling Link to comment Share on other sites More sharing options...
BBB Posted August 4, 2017 Share Posted August 4, 2017 I would start with the simple stuff, like adjusting the shifter rod and seeing if it makes a difference for you. Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
aeg Posted August 4, 2017 Share Posted August 4, 2017 The bike is under warranty. Bring it in and let them check. Link to comment Share on other sites More sharing options...
duhs10 Posted August 4, 2017 Share Posted August 4, 2017 The bike is under warranty. Bring it in and let them check. ^^^ This. Also, make sure you are letting the shifter come all the way back up after shifting down (or up for that matter). I've noticed this transmission prefers/needs that full "reset" between gears. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
isteve Posted August 4, 2017 Share Posted August 4, 2017 My FJ is coming up on 4 months also. I really haven't had any shifting problems but have had to adjust the clutch several times and around 2500 miles I lubed the shifter pivot. The pivot was dry like they forgot to lube it. If you are moving slow or not at all when downshifting most transmissions will find neutrals especially if the clutch needs adjusting and is dragging a little. Link to comment Share on other sites More sharing options...
xcsp Posted August 4, 2017 Share Posted August 4, 2017 My FJ is coming up on 4 months also. I really haven't had any shifting problems but have had to adjust the clutch several times and around 2500 miles I lubed the shifter pivot. The pivot was dry like they forgot to lube it. If you are moving slow or not at all when downshifting most transmissions will find neutrals especially if the clutch needs adjusting and is dragging a little.Little or no lube on pivot points is normal for Yamahas. Link to comment Share on other sites More sharing options...
rain Posted August 4, 2017 Share Posted August 4, 2017 Mine also, almost 6000 miles but has done it consistently since new. I just thought "they all do that", since others have termed the shifting as 'notchy'. FWIW, this only happens at low speed/low RPM downshifting, like when slowing to a stop and having to drop down 2 or 3 gears to get to first. If I downshift at more speed appropriate times, it's always smooth and consistent. (And I'm an under 5k rpm type of rider.) (mostly) Link to comment Share on other sites More sharing options...
duhs10 Posted August 4, 2017 Share Posted August 4, 2017 ...this only happens at low speed/low RPM downshifting, like when slowing to a stop and having to drop down 2 or 3 gears to get to first. If I downshift at more speed appropriate times, it's always smooth and consistent... I have experienced this on almost every motorcycle that I have ridden... i believe that is normal. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
suncoaster Posted August 5, 2017 Share Posted August 5, 2017 ...this only happens at low speed/low RPM downshifting, like when slowing to a stop and having to drop down 2 or 3 gears to get to first. If I downshift at more speed appropriate times, it's always smooth and consistent... I have experienced this on almost every motorcycle that I have ridden... i believe that is normal. This. Link to comment Share on other sites More sharing options...
tripleb Posted August 5, 2017 Author Share Posted August 5, 2017 Well I'm glad I'm not losing my mind and I'm not the only one with this issue. Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted August 5, 2017 Premium Member Share Posted August 5, 2017 I have experienced this on almost every motorcycle that I have ridden... i believe that is normal. This. This x3 Let’s go Brandon Link to comment Share on other sites More sharing options...
dbeau Posted August 6, 2017 Share Posted August 6, 2017 2017 with 3k miles here. Never experienced this. However I almost always shift down through each gear, engine braking through each gear as I come to a stop. Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted August 6, 2017 Premium Member Share Posted August 6, 2017 2017 with 3k miles here. Never experienced this. However I almost always shift down through each gear, engine braking through each gear as I come to a stop.I used to ride that way. I read that it caused significantly more tire wear. I stopped going through all the gears to slow and now down shift once stopped. My tires do seem to last longer. Let’s go Brandon Link to comment Share on other sites More sharing options...
outdoorvtguy Posted August 11, 2017 Share Posted August 11, 2017 As someone may have suggested already, have you tried adjusting the shift lever? I usually ride with fairly big boots ( for my big feet ) and adjusted the lever accordingly. On those odd days when I wear sneakers, I experience the same issue you mention because the lever is almost too high for the shoes. Just something to try. Link to comment Share on other sites More sharing options...
