jonno12345 Posted September 10, 2018 Share Posted September 10, 2018 Looks like I'm far too cheap for this page... I bought the following: https://www.ebay.co.uk/itm/282948930618 Along with a £2 relay. Placed it under the metal bracket that holds the seats and just plug in fuses and new spade connectors when I need another switched, fused item. Not the most space efficient way, but cheaper. Need a better solution for grounding, currently just attaching things to the frame as per the next image. The black wires are for my dash cams, ridiculously long compared to what I actually need and eventually I'll get around the cutting them to the size I actually need, they make it much messier... If you ignore those it's really not as untidy as it looks... Link to comment Share on other sites More sharing options...
norcal616 Posted September 10, 2018 Share Posted September 10, 2018 Looks like I'm far too cheap for this page... I bought the following: https://www.ebay.co.uk/itm/282948930618 Along with a £2 relay. Placed it under the metal bracket that holds the seats and just plug in fuses and new spade connectors when I need another switched, fused item. Not the most space efficient way, but cheaper. Need a better solution for grounding, currently just attaching things to the frame as per the next image. The black wires are for my dash cams, ridiculously long compared to what I actually need and eventually I'll get around the cutting them to the size I actually need, they make it much messier... If you ignore those it's really not as untidy as it looks... wheres the meatballs? ? 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
tinkerfreak Posted September 16, 2018 Share Posted September 16, 2018 Thanks Tinker. Look forward to it. Hey Okie, sorry but I did not get near my bike on my last days off due to overdue vehicle repairs which swamped me but I will make an effort to get the photos you requested on this series of days off. Cheers Link to comment Share on other sites More sharing options...
okietgtrider Posted September 16, 2018 Share Posted September 16, 2018 No worries Tinker. When you get to it is soon enough. Appreciated. Link to comment Share on other sites More sharing options...
tinkerfreak Posted September 30, 2018 Share Posted September 30, 2018 Hey Okie sorry for the delay; When I went to install the Eastern Beaver harness with the fuse panel(FP) I found that the portion of the harness that ran from the relay to the FP or the section from the battery terminal was going to be too short. If I had known, personally, I would have had them increase the section from the relay to the FP by 3" to 4". I hope the attached photos give you a better idea of where I am coming from. Let me know if you have any questions. Cheers Link to comment Share on other sites More sharing options...
Premium Member rustyshackles Posted September 30, 2018 Premium Member Share Posted September 30, 2018 I’ve been considering this as my accessory list has grown, what if anything is recommended to be on an unswitched circuit? IBA Member #59800 3 Nations Brewing Mug Club #100 Link to comment Share on other sites More sharing options...
jonno12345 Posted September 30, 2018 Share Posted September 30, 2018 I’ve been considering this as my accessory list has grown, what if anything is recommended to be on an unswitched circuit?Normally a battery tender is about it. I have a voltmeter/USB port attached unswitched too, only so I can see the battery voltage whilst it's off, and charge from the battery whilst off too if required. Everything else (which is now heated grips, heated seats, sat nav charger, dash cam and fog lights) are on a switched relay coming on when the tail light does. Link to comment Share on other sites More sharing options...
okietgtrider Posted September 30, 2018 Share Posted September 30, 2018 Thanks Tinker. All looks very neat. Hoping I'll do as well. I ordered up a PC8 with the standard length harness rather than the FJ-09 specific one. It's longer over all, think it will serve well with some room to spare. Appreciate you taking the time to take and post photos. Link to comment Share on other sites More sharing options...
okietgtrider Posted October 8, 2018 Share Posted October 8, 2018 Wired up the PC-8 today. Really was a breeze. Thanks Tinker for your pics. Link to comment Share on other sites More sharing options...
bugie Posted October 11, 2018 Share Posted October 11, 2018 To connect the wiring block to work on ignition would it require you to splice into the wiring loom? Could someone enlighten me how you would need to wire it up please? Link to comment Share on other sites More sharing options...
okietgtrider Posted October 11, 2018 Share Posted October 11, 2018 To connect the wiring block to work on ignition would it require you to splice into the wiring loom? Could someone enlighten me how you would need to wire it up please?Having just traveled this road I'll answer up. Yes. I tapped into the blue wire which is the taillight in the bundle that travels to the back of the bike. There may be better places to grab switched power, but this one worked for me. I found this page helpful in sorting out which wire I wanted. https://electricalconnection.com/index.php/2016/03/08/motorcycle-wire-color-codes/ Link to comment Share on other sites More sharing options...
bugie Posted October 12, 2018 Share Posted October 12, 2018 @okietgtrider Thanks Link to comment Share on other sites More sharing options...
2linby Posted November 9, 2018 Share Posted November 9, 2018 I have been making my own fuse blocks for years. Easy. Everything is simple, Nothing is easy Link to comment Share on other sites More sharing options...
