prn Posted March 24, 2017 Share Posted March 24, 2017 Does anyone have torque specs for long hex headed bolt near the foot peg that goes all the way to the other side and foot peg harness bolts on the right side? I need these for Givi TN2122 crash bar installation. ThanksIf you're going to do wrenching on the bike I recommend you invest in the service manual (dealer etc.). You might have a member recommend/specify values (we try to help), but mistakes do happen and on a motorcycle that can end tragically... use at own risk. Thank you very much for your help. I have ordered my service manual and it's on the way. 1 Link to comment Share on other sites More sharing options...
paulibiker Posted August 24, 2017 Share Posted August 24, 2017 Front sprocket nut torque? Link to comment Share on other sites More sharing options...
dbeau Posted August 24, 2017 Share Posted August 24, 2017 Front sprocket nut torque?69 lb.ft. Link to comment Share on other sites More sharing options...
Scooter426 Posted March 28, 2018 Share Posted March 28, 2018 Just remember to have someone push on the rear brake pedal when applying torque to the drive sprocket nut. Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted March 28, 2018 Premium Member Share Posted March 28, 2018 Just remember to have someone push on the rear brake pedal when applying torque to the drive sprocket nut. You can reach over and apply the brake with one hand and torque the nut with the other. Let’s go Brandon Link to comment Share on other sites More sharing options...
tobz Posted November 6, 2018 Share Posted November 6, 2018 This is helpful info. Link to comment Share on other sites More sharing options...
Premium Member fjray Posted June 2, 2019 Premium Member Share Posted June 2, 2019 On 2/28/2016 at 8:05 PM, martyl said: I have had the windshield adjustment knobs back out. Thankfully there is a clip at the end of the threaded part that keeps the knob from falling off. Something to check often. From the riders perspective the windshield knob on the left is the one that has the three positions to lock the knob into. That knob has been the one that backs out. The L bracket that is part of the assembly will rattle around if the knob is loose. Other than that I haven't had any other loose parts. It's always good to go over nuts n bolts periodically. I try to do that with my service intervals. The provided link doesn't take me to anything that helps me. My windshield knob keeps backing out on the one side and I don't have the solution. Do you remember the solution? Thanks in advance. Link to comment Share on other sites More sharing options...
Premium Member keithu Posted September 22, 2019 Premium Member Share Posted September 22, 2019 Does anyone know the torque for the camshaft journals? Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted September 22, 2019 Supporting Member Share Posted September 22, 2019 44 minutes ago, keithu said: Does anyone know the torque for the camshaft journals? 10Nm... image post failed miserably, sorry. 7.2 lb-ft... coat with oil. 1 Link to comment Share on other sites More sharing options...
WKE002 Posted August 16, 2020 Share Posted August 16, 2020 Please excuse my ignorant. Want to adjust my handlebar, these 4 nuts all torque 22nm as diagram only shows top 2 nuts to 22nm but bottom nuts does not state. Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted August 16, 2020 Supporting Member Share Posted August 16, 2020 (edited) 25 minutes ago, WKE002 said: Want to adjust my handlebar, these 4 nuts all torque 22nm as diagram only shows top 2 nuts to 22nm but bottom nuts does not state. I recall that they're all 16lb-ft on the FJ, but you torque down the front bolts first, then the rear. Edited August 16, 2020 by piotrek 1 Link to comment Share on other sites More sharing options...
jdavis Posted August 17, 2020 Share Posted August 17, 2020 29 ft/lb. pic only shows the r/h nut. 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted August 17, 2020 Supporting Member Share Posted August 17, 2020 10 hours ago, jdavis said: 29 ft/lb. pic only shows the r/h nut. I clearly missed the question. Thanks @jdavis. @WKE002!!! Link to comment Share on other sites More sharing options...
Premium Member fjray Posted November 1, 2020 Premium Member Share Posted November 1, 2020 On 11/4/2015 at 3:31 PM, josh said: Make sure you don't over tighten the oil drain plug, I guess I did and pulled all the aluminums threads. FML- Helli coil repair kit 70.00, new oil 65.00. What a expensive lesson learned. New oil over $20.00 a quart? Link to comment Share on other sites More sharing options...
nhchris Posted November 1, 2020 Share Posted November 1, 2020 Can someone please provide the torque spec for the engine clutch cover bolts on the right side of the motor? Thanks 1968 Triumph Bonneville 650 1971 Norton Commando Roadster 2002 Harley 1200 Sportster 2003 Honda ST 1300 2016 FJ 09 Link to comment Share on other sites More sharing options...
