Premium Member javashot1 Posted February 9, 2016 Premium Member Share Posted February 9, 2016 I have a torque wrench I just failed to use it.The thread size is M14X1.5Helli-coil part number 5544-14 and it comes with 3 or 4 inserts. Thanks , I've opted to go ahead and replace with the updated 2016 strainer cover (oil pan). Link to comment Share on other sites More sharing options...
josh Posted February 10, 2016 Share Posted February 10, 2016 I think I might also, I'm really hoping that Yamaha will recall it, but I doubt that will happen Link to comment Share on other sites More sharing options...
kd7vdb Posted February 19, 2016 Share Posted February 19, 2016 Does anyone have the torque value for the upper bag mounts on the side of the tail? My mounts can both wiggle around. Oh and the value for the bar-end bolts one of mine came out a cm or so in the first 100 miles. Link to comment Share on other sites More sharing options...
skipperT Posted February 20, 2016 Share Posted February 20, 2016 For which bags? The Yamaha removable "city" cases? Those mounting bolts torque to 25 ft lbs, if the rear luggage rack is installed. Inside the tail, for the mounts for the luggage: m6 bolts 7.2 ft lbs, m8 bolt is 21 ft lbs, corresponding nut is 16 ft. If yours are loose, you may want to call your dealer. I've heard there is a tech bulletin from Yamaha about excessive movement from the saddlebag mounts and how to tighten things up. Skip Link to comment Share on other sites More sharing options...
kd7vdb Posted February 20, 2016 Share Posted February 20, 2016 For which bags? The Yamaha removable "city" cases? Those mounting bolts torque to 25 ft lbs, if the rear luggage rack is installed. Inside the tail, for the mounts for the luggage: m6 bolts 7.2 ft lbs, m8 bolt is 21 ft lbs, corresponding nut is 16 ft. If yours are loose, you may want to call your dealer. I've heard there is a tech bulletin from Yamaha about excessive movement from the saddlebag mounts and how to tighten things up. Skip I was actually looking for the spec for the stock plastic slots that come on the bike without the rear rack. I am going to assume it is the same though I can't see a reason why it would be different. Link to comment Share on other sites More sharing options...
skipperT Posted February 20, 2016 Share Posted February 20, 2016 Oh ok. Those are slightly less, actually (without the rack. ) 20ft lbs I believe. S Link to comment Share on other sites More sharing options...
kd7vdb Posted February 20, 2016 Share Posted February 20, 2016 Oh ok. Those are slightly less, actually (without the rack. ) 20ft lbs I believe. S I ended up tightening them to 30ft lbs yesterday so they should be good to go (added loctite too). I also had one of the button heads on the tank trim was a little loose. I tried to remove it and it went immediately to swiss cheese ;-| . I ordered 4 extras PN 90111-05007-00. Luckily my local dealer was able to order them with their regular order as it is a part number that has been used on motorcycles and boat motors for years. Link to comment Share on other sites More sharing options...
redfjniner Posted February 21, 2016 Share Posted February 21, 2016 Oh ok. Those are slightly less, actually (without the rack. ) 20ft lbs I believe. S I ended up tightening them to 30ft lbs yesterday so they should be good to go (added loctite too). I also had one of the button heads on the tank trim was a little loose. I tried to remove it and it went immediately to swiss cheese ;-| . I ordered 4 extras PN 90111-05007-00. Luckily my local dealer was able to order them with their regular order as it is a part number that has been used on motorcycles and boat motors for years. Good learning technic. Trial and error. Good luck, keep up the good work. Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 114,000 m (Replaced engine at 106K) Link to comment Share on other sites More sharing options...
bobdog Posted February 28, 2016 Share Posted February 28, 2016 Fellow FJ 09ers, I've come to the conclusion that just about every bolt on this bike (any bike) needs to be given a dose of loctite and a good retorquing. If the button heads on the trim's 1/4 turn fasteners get loose, check the clip they lock into. It's the usual suspect... 2015 Grey FJ09 with a few tweaks, 2007 HD Street Glide - Good Bike + Good Friends = Good Day. Link to comment Share on other sites More sharing options...
Premium Member clint Posted February 29, 2016 Premium Member Share Posted February 29, 2016 Fellow FJ 09ers, I've come to the conclusion that just about every bolt on this bike (any bike) needs to be given a dose of loctite and a good retorquing. If the button heads on the trim's 1/4 turn fasteners get loose, check the clip they lock into. It's the usual suspect...Interesting, I've not had any issues with bolts, screws or nuts coming loose at all. Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
Premium Member fddriver2 Posted February 29, 2016 Premium Member Share Posted February 29, 2016 Fellow FJ 09ers, I've come to the conclusion that just about every bolt on this bike (any bike) needs to be given a dose of loctite and a good retorquing. If the button heads on the trim's 1/4 turn fasteners get loose, check the clip they lock into. It's the usual suspect...My other bike is a 2009 HD XR1200. That I have put 45,000 miles on since Oct 2011. The idea that more fasteners could fall off my FJ then that thing is hysterical..... Here is an example of the issues you face with that American bike.... "It doesn't matter who walks in, you know the joke is still the same" Ft. Lauderdale, Florida. USA Link to comment Share on other sites More sharing options...
Premium Member martyl Posted February 29, 2016 Premium Member Share Posted February 29, 2016 I have had the windshield adjustment knobs back out. Thankfully there is a clip at the end of the threaded part that keeps the knob from falling off. Something to check often. From the riders perspective the windshield knob on the left is the one that has the three positions to lock the knob into. That knob has been the one that backs out. The L bracket that is part of the assembly will rattle around if the knob is loose. Other than that I haven't had any other loose parts. It's always good to go over nuts n bolts periodically. I try to do that with my service intervals. A Motorcyclist's Church is the open road.... Link to comment Share on other sites More sharing options...
Premium Member michael Posted February 29, 2016 Premium Member Share Posted February 29, 2016 Hate to be an HD apologist, but isn't that a German exhaust that came apart in that picture? Kinda hard to blame HD for an aftermarket exhaust failure. Link to comment Share on other sites More sharing options...
Premium Member fddriver2 Posted February 29, 2016 Premium Member Share Posted February 29, 2016 Hate to be an HD apologist, but isn't that a German exhaust that came apart in that picture? Kinda hard to blame HD for an aftermarket exhaust failure. Kinda German. (Austria) Remus Revolution Exhaust Silencer Revolution is a high performance silencer from the Austrian Sport Exhaust manufacturing experts Remus That was just a picture of one of the latest "issues" I've traveled a bunch on it and with other HD riders, fasteners and other things falling off is a common HD problem.. Lol. That little tail bag is full of spare stuff out of necessity... "It doesn't matter who walks in, you know the joke is still the same" Ft. Lauderdale, Florida. USA Link to comment Share on other sites More sharing options...
Premium Member clint Posted February 29, 2016 Premium Member Share Posted February 29, 2016 I have had the windshield adjustment knobs back out. Thankfully there is a clip at the end of the threaded part that keeps the knob from falling off. Something to check often. From the riders perspective the windshield knob on the left is the one that has the three positions to lock the knob into. That knob has been the one that backs out. The L bracket that is part of the assembly will rattle around if the knob is loose. Other than that I haven't had any other loose parts. It's always good to go over nuts n bolts periodically. I try to do that with my service intervals.There's a perfect fix for those windscreen knobs. http://fj-09.org/thread/963/loose-windshield-adjusters-simple-fix Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
