Premium Member martyl Posted February 29, 2016 Premium Member Share Posted February 29, 2016 Thanks! RIde to Home Depot I go! A Motorcyclist's Church is the open road.... Link to comment Share on other sites More sharing options...
robbgt Posted April 14, 2016 Share Posted April 14, 2016 Nomenclature, Torque Value, Fluid Types/Quantities Exhaust pipe nut, 14 lb ft (20 Nm) Can someone confirm that this is the torque for the Engine - Header/exhaust torque? Thanks! '15 FJ-09 (Red) - DIY OEM Tidy Tail - Updated Oil Pan Link to comment Share on other sites More sharing options...
philippevanlombeek Posted April 14, 2016 Share Posted April 14, 2016 Nomenclature, Torque Value, Fluid Types/Quantities Exhaust pipe nut, 14 lb ft (20 Nm) Can someone confirm that this is the torque for the Engine - Header/exhaust torque? Thanks! That's the right torque for the Engine - Header/exhaust Link to comment Share on other sites More sharing options...
robbgt Posted April 14, 2016 Share Posted April 14, 2016 Can someone confirm that this is the torque for the Engine - Header/exhaust torque? Thanks! That's the right torque for the Engine - Header/exhaust Perfect, thank you for confirming. I finished up installing the updated oil pan last night and was unsure of this spec to re-install the exhaust. '15 FJ-09 (Red) - DIY OEM Tidy Tail - Updated Oil Pan Link to comment Share on other sites More sharing options...
berryber Posted May 26, 2016 Share Posted May 26, 2016 Thanks for the info. ULEWZ Link to comment Share on other sites More sharing options...
letsride Posted July 2, 2016 Share Posted July 2, 2016 Does anyone know the torque spec for the oil strainer cover? Link to comment Share on other sites More sharing options...
thruster8999 Posted July 2, 2016 Share Posted July 2, 2016 Does anyone know the torque spec for the oil strainer cover? If you talking about the two bolts that hold that eye shape cover for the strainer the books says 10 Nm (1.0 - kgf, 7.2 ft Ibf). I would just tighten it by hand. Link to comment Share on other sites More sharing options...
letsride Posted July 4, 2016 Share Posted July 4, 2016 Nope, I'm referring to the 15 bolts that attach the oil strainer cover (or oil pan) to the bottom of the engine. Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted July 5, 2016 Premium Member Share Posted July 5, 2016 Oil pan bolts - 10 Nm (1.0 m-kgf, 7.2 ft-lbf) Link to comment Share on other sites More sharing options...
letsride Posted July 6, 2016 Share Posted July 6, 2016 Thanks. I figured I'd need an inch/pound wrench on them. Link to comment Share on other sites More sharing options...
jo Posted August 24, 2016 Share Posted August 24, 2016 Not sure what it's called but anyone have the torque spec for the handlebar clamp? The 4 screws at the top holding the handlebar Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted August 24, 2016 Premium Member Share Posted August 24, 2016 Handle bar Holder Bolts 22 Nm (2.2 m kgf, 16 ft lbf) Link to comment Share on other sites More sharing options...
jsp Posted August 24, 2016 Share Posted August 24, 2016 Not sure what it's called but anyone have the torque spec for the handlebar clamp? The 4 screws at the top holding the handlebarBe sure to torque the front bolts fully with zero gap between the top and bottom clamp before you torque the rear bolts. john Link to comment Share on other sites More sharing options...
prn Posted March 23, 2017 Share Posted March 23, 2017 Does anyone have torque specs for long hex headed bolt near the foot peg that goes all the way to the other side and foot peg harness bolts on the right side? I need these for Givi TN2122 crash bar installation. Thanks Link to comment Share on other sites More sharing options...
duhs10 Posted March 24, 2017 Share Posted March 24, 2017 Edit.. @piotrek.. I think you found the right one. The one I was looking at is for the upper shock mount. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
