y4panda Posted April 29, 2015 Share Posted April 29, 2015 Thanks or the useful instruction and good photos. I did notice Yamaha's instruction mentions silicone grease rather than the lithium grease you suggest in step #9. I just used some lithium grease I had on hand. Link to comment Share on other sites More sharing options...
mjsracing Posted April 29, 2015 Share Posted April 29, 2015 While I was removing the ECU... I took a couple of photos of the grip heater electrical connectors. 2015 FJ-09, 2016 1290 Super Duke, 2017 150 XC-W (primary ride), 2012 DR650 Link to comment Share on other sites More sharing options...
timo50 Posted May 27, 2015 Share Posted May 27, 2015 Just ordered a pair of heated grips and found this very helpful, many thanks. Link to comment Share on other sites More sharing options...
root Posted June 27, 2015 Share Posted June 27, 2015 The pictures were very helpful. Thank you very much for that. Much clearer than the instructions that came with the grips. I will say the toughest part was the left grip, both getting the stock one off and the new one on. The rest of it just took patience to figure out the best way to route things and get back together. The loop in the wire on the right side was weird and tricky to get but once it was together it went just fine. Link to comment Share on other sites More sharing options...
traceroz Posted July 4, 2015 Share Posted July 4, 2015 My grips finally arrived! I fitted them yesterday, and have a couple more tips to add: - I found it easier to do the cable looping and fitting of the plastic guide on the bench. The screw for the guide is tiny, and can be easily dropped if trying to hold everything on the bike. - Get some extra cable ties, there are only 3 supplied with the kit, and I feel that the cables need to be secured in more points than that. - The new throttle tube is dry, so don't forget to apply a thin film of lithium grease to the handlebar to keep it twisting smooth. Also grease the areas where the cable barrels insert. - The kit has a new bar-end mount supplied for the throttle side. Don't forget to fit it! Link to comment Share on other sites More sharing options...
Guest rszk Posted July 5, 2015 Share Posted July 5, 2015 I want to thank ULEWZ for initiating this thread. I had my heated grips on backorder since March and got them in just before my trip. I decided against putting them in until after as I was not going to need them with the extremely high temperatures we were getting. I just installed them today. Very easy installation. I've done other brands before, but not the OEM Yamaha's. The Yamaha instructions coupled with these online pictorials made it a painless affair. Cheers! Link to comment Share on other sites More sharing options...
doctore777 Posted August 9, 2015 Share Posted August 9, 2015 Thanks for the great write-up! Took 30 minutes and some of my wife's Aquanet! Really appreciate the pictures and details as the Yamaha instructions left a lot to be desired! Cheers! Link to comment Share on other sites More sharing options...
air Posted August 14, 2015 Share Posted August 14, 2015 Thanks. 1 hour. Link to comment Share on other sites More sharing options...
nihilist Posted August 25, 2015 Share Posted August 25, 2015 You guys all make it sound so easy, but the instructions are a little intimidating as I have no experience with messing with a bike to this extent. I like to think I'm a smart guy and I've done superficial installs like hardbags, back rests, winshields, etc, but I'm wondering if I would be out of my depth in attempting this. I'm always up for a challenge, but I don't want to f*** up my bike. Can anyone comment as to whether this is a reasonable project for someone with very little experience in such things? Much appreciated. //QED Link to comment Share on other sites More sharing options...
Premium Member cman Posted August 26, 2015 Premium Member Share Posted August 26, 2015 I'm kinda in the same boat as you @nihilist. Granted, I did my own throttle body sync and removed my ECU to get it flashed. But, those looked pretty easy and I knew I could stop at any time I felt over my head. I still haven't decided if I'm going to order the heated grips (I'm not sure they're needed here in Texas), but if I do, I'll still need to decide if I want to install them myself or pay the dealer. Link to comment Share on other sites More sharing options...
Premium Member ULEWZ Posted August 26, 2015 Author Premium Member Share Posted August 26, 2015 You guys all make it sound so easy, but the instructions are a little intimidating as I have no experience with messing with a bike to this extent. I like to think I'm a smart guy and I've done superficial installs like hardbags, back rests, winshields, etc, but I'm wondering if I would be out of my depth in attempting this. I'm always up for a challenge, but I don't want to f*** up my bike. Can anyone comment as to whether this is a reasonable project for someone with very little experience in such things? Much appreciated. Easy weasy. If you can wipe your a$$, you can do this. Maybe a little hyperbole, but you get the point. I will be available when you try this incase you run into problems but I don't think it will be required. Buy the kit, take it out of the box and ask away after you review the pictures and writeup. If you are ever in So. Cal I will do it for you. A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
nihilist Posted August 26, 2015 Share Posted August 26, 2015 Thanks for the offer, I'll keep that in mind. Borrow an air compressor, buy lube and glue....so I'm doing it myself to save $80. As long as it's not too difficult it's worthwhile. //QED Link to comment Share on other sites More sharing options...
nihilist Posted September 22, 2015 Share Posted September 22, 2015 You guys all make it sound so easy, but the instructions are a little intimidating as I have no experience with messing with a bike to this extent. I like to think I'm a smart guy and I've done superficial installs like hardbags, back rests, winshields, etc, but I'm wondering if I would be out of my depth in attempting this. I'm always up for a challenge, but I don't want to f*** up my bike. Can anyone comment as to whether this is a reasonable project for someone with very little experience in such things? Much appreciated. Easy weasy. If you can wipe your a$$, you can do this. Maybe a little hyperbole, but you get the point. I will be available when you try this incase you run into problems but I don't think it will be required. Buy the kit, take it out of the box and ask away after you review the pictures and writeup. If you are ever in So. Cal I will do it for you. It seems you were indeed correct. There was nothing particularly difficult about the install - it was merely a bit fiddly at some points. The air compressor trick worked amazingly well, but the trick was figuring out how to do it right. Once you do, the grip blows up and slides off. The fairings were annoying because the right side doesn't fit precisely the same as the left. There is a very slight gap between the upper fairing and the the headlight cowl/assembly. This drove me nuts and took the most time of the whole process. All in all, not nearly as difficult as I had feared. And holy crap do those grips get hot! The default high setting is 5 or 6 (I haven't checked), and it's painfully hot. I can't imagine having it set to 10! I'm pretty sure that's 1st degree burns territory. Thanks for the encouragement! //QED Link to comment Share on other sites More sharing options...
mhevezi Posted September 22, 2015 Share Posted September 22, 2015 The left side is oh-my-gawd-falling-off-a-curb-and-landing-on-my-butt easy. Seriously. The throttle side is a little more tricky, due to the loop you need to add, to let the throttle move freely. Not that bad, and the post REALLY helps. Just pay close attention to how the throttle cables come off the bike and you'll be fine. They really are plug&play. Happy Hands. Link to comment Share on other sites More sharing options...
rocky5000100 Posted September 22, 2015 Share Posted September 22, 2015 Ha you guys saved your stock grips? I cut those suckers off lol. My air compressor decided it didn't' want to work. Besides, new grips (if I wanted to take off the heated?) are $10. I'm pretty used to cutting off my grips each race season and adding new ones so I guess I didn't have any reservation about doing it haha. Oh yea, and I've seen it mentioned before, but hair spray works great instead of grip glue. Link to comment Share on other sites More sharing options...
