pgf Posted February 26, 2015 Share Posted February 26, 2015 how often do the valves need to be checked/adjusted on this engine? i assume it's shim under bucket? how hard is it to get to the heads? Link to comment Share on other sites More sharing options...
deersSlayer Posted February 26, 2015 Share Posted February 26, 2015 how often do the valves need to be checked/adjusted on this engine? i assume it's shim under bucket? how hard is it to get to the heads? It's harder than using a shift key. Valve adjustment check is every 42,000 km. FJ-09, 690 Enduro R. Back Roads. Period. Link to comment Share on other sites More sharing options...
pgf Posted February 26, 2015 Author Share Posted February 26, 2015 how often do the valves need to be checked/adjusted on this engine? i assume it's shim under bucket? how hard is it to get to the heads? It's harder than using a shift key. Valve adjustment check is every 42,000 km. wow -- excellent!! sounds like i may never need to do either one. ;-) ;-) Link to comment Share on other sites More sharing options...
xcsp Posted February 26, 2015 Share Posted February 26, 2015 26,000 miles / 42,000 km Link to comment Share on other sites More sharing options...
