Jiri Posted April 24, 2019 Share Posted April 24, 2019 On 5/23/2018 at 12:16 AM, pattonme said: if the new spring was made to the OE specs, it has too much baseline preload. Yamaha cheated instead of doing the right thing. Get a standard length EIBACH and have a machinist knock out a spacer that yields at least 8mm of baseline preload. I guess I could make said spacer, I got a few OE shocks sitting around here and could figure out the dimensions... More to the point, aside from being short on sag, does the bike ride to your satisfaction? I have Tracer 900 (FJ09) MY 2017. My weight is 95kg without gear. OEM front spring was too soft - > static and rider sag to big and rear spring is too hard -> static and rider sag too small. I have replaced front spring by Wilbers progresive with stiffness 8,5N/mm - 10,5 N/mm (free lenght 300mm) and changed oil (slightly thinner Wibers), set 10 clicks rebound out of closed and now the front end is better - front static sag 26, rider sag 46mm. The OEM rear is too hard - static sag 6-8mm only and rider sag 33-35mm. I would like to change rear spring to reach the right sag, but I am not sure what is stiffness of OEM rear spring (for M.Y. 2015 was 99,9N/mm, but I am not sure if M.Y. 2017 is the same). Could you advise? I found 95NM rear spring by K-Tech. I drive always without pillion, sometimes with light luggage (max. up to 20kg). Link to comment Share on other sites More sharing options...
