Guest redneck Posted March 1, 2015 Share Posted March 1, 2015 Seeing that we still have a ton of snow here in Ottawa, I've decided to look through my spare parts bin and install flush mount LED turn signals on my new bike. I've picked these up on ebay last year to install on my FZ1 but they were too small http://www.ebay.ca/itm/Motorcycle-Flush-Mount-LED-Turn-Signal-Blinker-Light-For-YZF-R1-R6-FZ-1-Yamaha-/181678190311?pt=Motorcycles_Parts_Accessories&hash=item2a4cdd2ee7&vxp=mtr The dimensions of the lights are 1 5/8 X 1" and they fit nicely. [ul type=disc][*]First step, remove the 3 Hex screws to remove the side panel. Do be careful, there's a tab in the bottom of the panel and press fit stud at the top. Unplug the stock turn signal.[*]Separate the side panel by removing the 2 hex screws and the 4 press fit washers[*]Remove the stock turn signal.[*]At this point I cut the wiring to splice the factory connector with the aftermarket light. The black wire is the ground, the blue is for "park" light which I didn't use in this application and the green or brown depending on the side is the turn signal which is spliced to the yellow wire.[*]install new signal light and secure the set plate. I used silicone on the thread so the back plate wouldn't come undone.[*]Re-assemble the panel.[*]Re-install the panel on the bike[*]It took me about an hour to complete the project and cost less than 10$ for a much cleaner look. [/ul] Link to comment Share on other sites More sharing options...
FigJam-OhNine Posted March 1, 2015 Share Posted March 1, 2015 Same lights I have. They work great! Not quite ''flush" but still. Link to comment Share on other sites More sharing options...
deersSlayer Posted March 1, 2015 Share Posted March 1, 2015 Seeing that we still have a ton of snow here in Ottawa, I've decided to look through my spare parts bin and install flush mount LED turn signals on my new bike. Another Ottawan with a parked FJ-09, we need a support group! FJ-09, 690 Enduro R. Back Roads. Period. Link to comment Share on other sites More sharing options...
Guest redneck Posted March 1, 2015 Share Posted March 1, 2015 big time, Wheelsport delivered mine in early feb and it's been freezing ever since. can't wait to take the beast out, it should be a major upgrade from my 05 FZ1. a lot lighter and nimble feeling Link to comment Share on other sites More sharing options...
Guest redneck Posted March 3, 2015 Share Posted March 3, 2015 and I just found these last night, http://www.ebay.ca/itm/Yamaha-Turn-Signal-Wiring-Harness-Connectors-Adapter-Plug-2-wires-160mm-/171703180565?pt=Motorcycles_Parts_Accessories&hash=item27fa4e9d15&vxp=mtr they would have saved a lot of time splicing. I still ordered a set for when I get the tail tidy Link to comment Share on other sites More sharing options...
RandyD Posted March 3, 2015 Share Posted March 3, 2015 Nice find on the adapters. He sells art for the front 3 wire also. Link to comment Share on other sites More sharing options...
jaxn Posted May 2, 2015 Share Posted May 2, 2015 Nice write up. I like the idea of flushmount LEDs to accent the knuckle guard lights I hope to get soon. Tempted to also run a set in the rear when I swap out taillights. Can someone post a pic of what these flushmount LEDs look like installed on the FJ? I'd like to see how clean the look is before pulling the trigger. Thanks. Link to comment Share on other sites More sharing options...
