duhs10 Posted August 24, 2018 Share Posted August 24, 2018 ALL MY VALVES WERE VERY TIGHT AT 24,000 MILES REINSTALLING CAMS INDEXED (TIMED) CORRECTLY IS CHALLENGING TO SAY THE LEAST. I HAVE TO GO BACK IN AND CHECK THE CAM TIMING AND BE SURE THE CAM CHAIN IS TIGHT ON THE EXHAUST SIDE. MY APE CCT WILL TAKE CARE OF THE INTAKE SIDE (I DID HAVE THE CCT REPLACED PER THE TSB BUT BASED ON WHAT I'VE READ DO NOT TRUST EVEN THE LATEST OEM CCT). I HAVE A THROTTLE CHOP IDLE DROP ISSUE I'VE POSTED ABOUT ELSEWHERE I BELIEVE IS RELATED TO BEING OFF ONE CAM CHAIN SPROCKET TOOTH ON ONE OR BOTH OF THE CAMS DUE THE DIFFICULTY OF REINSTALLING THE CAMS... ANYONE KNOW WHAT I'M TALKING ABOUT? @skippert Any help? '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
skipperT Posted August 24, 2018 Share Posted August 24, 2018 They suck to put back in and get timed correctly. VERY easy to jump a tooth. The running condition could absolutely be caused by being off a tooth. However, I’m not sure this engine will even rotate over completely without hitting valves on pistons if the timing is off a tooth. Could be something else as well. Need more info. -Skip Link to comment Share on other sites More sharing options...
koth442 Posted August 24, 2018 Share Posted August 24, 2018 My Daytona 675, also an interference motor, ran 1 tooth off. '15 FJ09 Link to comment Share on other sites More sharing options...
skipperT Posted August 24, 2018 Share Posted August 24, 2018 My Daytona 675, also an interference motor, ran 1 tooth off. That’s interesting! Must have a sweet non-interface spot somewhere in order for that to happen. ? -Skip Link to comment Share on other sites More sharing options...
koth442 Posted August 24, 2018 Share Posted August 24, 2018 My friend who used to be a race engineer on the AMA Factory road racing team said they'd run 1-1.5 teeth advanced sometimes. Typically 1-1.5 teeth isn't enough for a collision. He said 3 teeth is almost guaranteed piston / valve collision. 2 teeth is a maybe, but 1 tooth is typically not an issue. Motor has to be tuned for that change in cam timing though. They achieved 1.5 teeth by machining the mounting hole in the cams a bit. '15 FJ09 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted August 24, 2018 Premium Member Share Posted August 24, 2018 If I am off one or more teeth on the intake and or the exhaust cams it's certainly will run without things kissing each other badly. I've checked everything else that I can think of about for the condition I'm experiencing. Specifically, if you Rev the engine and then let go allowing to drop back down it dips below normal idle speed for a split second and then comes back up to standard idle speed. This split-second hiccup when riding can cause a stall at low speeds, it can be ridden around by keeping the revs up but it is annoying to a anal retentive / add / dyslexic like me. And it only began after I adjusted the valves and replaced the cam chain tensioner. I also of course changed the plugs, checked the throttle body sync and adjusted the accelerator position module. I triple checked the CCT, TB sync and AP settings, so it seems the only variable is the cam timing and possible resulting excess slack on the exhaust side of the cam chain. Link to comment Share on other sites More sharing options...
skipperT Posted August 25, 2018 Share Posted August 25, 2018 If I am off one or more teeth on the intake and or the exhaust cams it's certainly will run without things kissing each other badly. I've checked everything else that I can think of about for the condition I'm experiencing. Specifically, if you Rev the engine and then let go allowing to drop back down it dips below normal idle speed for a split second and then comes back up to standard idle speed. This split-second hiccup when riding can cause a stall at low speeds, it can be ridden around by keeping the revs up but it is annoying to a anal retentive / add / dyslexic like me. And it only began after I adjusted the valves and replaced the cam chain tensioner. I also of course changed the plugs, checked the throttle body sync and adjusted the accelerator position module. I triple checked the CCT, TB sync and AP settings, so it seems the only variable is the cam timing and possible resulting excess slack on the exhaust side of the cam chain. You seem fairly confident in that statement, and I would caution that you just never know, especially with today’s high compression ratio engines. I recently had a single cylinder 14 YZ450F apart that had the intake timing 1 tooth off and it bent a valve. YMMV. Sounds like you have narrowed it down pretty well as to what it might be. I would also verify that the APS/TPS numbers are where you think they should be (takes 2 seconds) and I’d also verify sensor and electrical connections of everything you disconnected (some can be mixed up, ie intake air pressure sensor if memory serves). It could also be as simple as the throttle body not being all the way seated in the intake manifolds, or some other kind of intake leak. Good luck, -S Link to comment Share on other sites More sharing options...
gv550 Posted August 1, 2019 Share Posted August 1, 2019 (edited) I just completed a valve clearance check and adjustment on my 9 month old GT, well before the recommended 42k. All intake valves were within spec, .14, .16, .16, .16, .15 and .14 mm clearances, spec is .11 to .20 mm. All 6 exhaust valves were tight, .15, .20, .18, .20, .20, .20 mm clearances, spec is .26 to .30 mm. Swapped one shim and bought 5 new ones to end up with .28 to .30 so should be good to go for a while. I'll likely check them again in 20,000 kms, sure not comfortable letting them go to 42k. I combined this job with a chain replacement and steering bearing service, having the front wheel and forks out of the way sure makes this easy. Edited August 11, 2019 by gv550 2 2019 Tracer GT, Ontario, Canada Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted August 1, 2019 Supporting Member Share Posted August 1, 2019 50 minutes ago, gv550 said: I just completed a valve clearance check and adjustment on my 9 month old GT, 30,600 kms which is well before the recommended 42k. .......... All 6 exhaust valves were tight, .15, .20, .18, .20, .20, .20 mm clearances, spec is .26 to .30 mm. Swapped one shim and bought 5 new ones to end up with .28 to .30 so should be good to go for a while. I'll likely check them again in 20,000 kms, sure not comfortable letting them go to 42k. .......... Thanks for posting the data. Same old... that lash check interval for the CP3 is way optimistic. 1 Link to comment Share on other sites More sharing options...
tktplz Posted August 3, 2019 Share Posted August 3, 2019 (edited) If you do your own valve adjs as I do here's a chart to help with valve sizes needed with the clearance you have before the change; file:///C:/Users/TKTPKZ/Documents/Valve%20Adj%20Files/Valve%20adjustment%20calculator.htm Hopefully the link will work........I used it for my ZRX1100 and my ZX11 but it will work with most bikes. I just like that it does the math for you. You put in the intake lower and upper clearance and your measurements of what you have , it tells you the size shim you need. Same with exhaust. Edited August 3, 2019 by tktplz 1 Ain't no fun when the rabbit gets the gun! Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted August 3, 2019 Author Supporting Member Share Posted August 3, 2019 46 minutes ago, tktplz said: file:///C:/Users/TKTPKZ/Documents/Valve%20Adj%20Files/Valve%20adjustment%20calculator.htm 47 minutes ago, tktplz said: If you do your own valve adjs as I do here's a chart to help with valve sizes needed with the clearance you have before the change; file:///C:/Users/TKTPKZ/Documents/Valve%20Adj%20Files/Valve%20adjustment%20calculator.htm Hopefully the link will work........I used it for my ZRX1100 and my ZX11 but it will work with most bikes. I just like that it does the math for you. You put in the intake lower and upper clearance and your measurements of what you have , it tells you the size shim you need. Same with exhaust. That doesn't work as a link, it looks like the file directory location on your hard drive. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
tktplz Posted August 3, 2019 Share Posted August 3, 2019 (edited) Yeah, found it in documents, it's a zip file but doesn't end in jpeg. jpe, jpg, etc. it's about 8.5 MBs. Edited August 3, 2019 by tktplz Ain't no fun when the rabbit gets the gun! Link to comment Share on other sites More sharing options...
