BBB Posted August 3, 2020 Share Posted August 3, 2020 @iitywygms, I find that the top of the centre stand pad can hit the bottom of the silencer. It’s worth a check that you have clearance. Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
iitywygms Posted August 3, 2020 Share Posted August 3, 2020 9 minutes ago, BBB said: @iitywygms, I find that the top of the centre stand pad can hit the bottom of the silencer. It’s worth a check that you have clearance. Thanks for the heads up. I actually trimmed the plastic piece to raise the center stand for more clearance. Still have 1/4 inch clearance with no chance of hitting the can. Link to comment Share on other sites More sharing options...
iitywygms Posted August 3, 2020 Share Posted August 3, 2020 3 hours ago, Willie17FJ-09 said: Do you get much back firing on deceleration? Zero backfiring. But I have a ecu tune by Ivan. Let me say again that this is just plain awesome. Link to comment Share on other sites More sharing options...
iitywygms Posted August 3, 2020 Share Posted August 3, 2020 6 hours ago, jdavis said: I found, and a few others, that the pipe is a tad restrictive at high rpm's. I drilled a few extra holes in the baffle to fix this problem. Im running no baffle. 1 Link to comment Share on other sites More sharing options...
stizo Posted August 27, 2020 Share Posted August 27, 2020 Finally got one ordered and on it's way from MotoMachines and found a full system locally for $50 to chop up. Question, are you guys cutting before, after or centered on the weld? Planning on using a chop saw to make the cut and grinder to clean up accordingly. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted August 27, 2020 Supporting Member Share Posted August 27, 2020 6 hours ago, stizo said: Finally got one ordered and on it's way from MotoMachines and found a full system locally for $50 to chop up. Question, are you guys cutting before, after or centered on the weld? Planning on using a chop saw to make the cut and grinder to clean up accordingly. When I cut mine I cut it just before the weld, if I was going to do it again I would try and cut as far back as possible. I believe the instructions want you to have 15mm behind the O2 sensor, mine is a bit short but haven't noticed any exhaust leaking. 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted August 28, 2020 Supporting Member Share Posted August 28, 2020 (edited) 10 hours ago, stizo said: Question, are you guys cutting before, after or centered on the weld? Planning on using a chop saw to make the cut and grinder to clean up accordingly. I cut it to get my 15mm... wherever it landed on the pipe. Used a cutting wheel on an angle grinder and then spent a good chunk of time cleaning with a grinder and a file. Take your time and test fit frequently... you have one shot at it. Edited August 28, 2020 by piotrek 3 Link to comment Share on other sites More sharing options...
BBB Posted August 28, 2020 Share Posted August 28, 2020 Here's where I cut mine 3 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
stizo Posted September 3, 2020 Share Posted September 3, 2020 (edited) Slip on arrived Monday and had a chance to install today. So loud without the baffle... I love it. 😁 Edited September 3, 2020 by stizo 1 Link to comment Share on other sites More sharing options...
BBB Posted September 3, 2020 Share Posted September 3, 2020 Looks great @stizo, have fun with it. Things to consider next (if you haven’t already) are an ECU flash and drilling a few holes in the baffle if you ride with it in. 1 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
stizo Posted September 3, 2020 Share Posted September 3, 2020 13 minutes ago, BBB said: Looks great @stizo, have fun with it. Things to consider next (if you haven’t already) are an ECU flash and drilling a few holes in the baffle if you ride with it in. Thanks. Ecu has already been flashed for stock exhaust. Need to road test it to see if it needs to be redone (flat spots, sputters etc). Just revving in the garage and already opted for baffle out. Link to comment Share on other sites More sharing options...
BBB Posted September 3, 2020 Share Posted September 3, 2020 10 hours ago, stizo said: Thanks. Ecu has already been flashed for stock exhaust. Need to road test it to see if it needs to be redone (flat spots, sputters etc). Just revving in the garage and already opted for baffle out. Your tuner may reflash for free, but mine was definitely flat feeling on the standard tune with the baffle in. It’s definitely too loud with the baffle out for me, but a few extra holes gave me the best balance of sound and smooth performance. 3 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
stizo Posted September 3, 2020 Share Posted September 3, 2020 5 hours ago, BBB said: Your tuner may reflash for free, but mine was definitely flat feeling on the standard tune with the baffle in. It’s definitely too loud with the baffle out for me, but a few extra holes gave me the best balance of sound and smooth performance. Took it out for a quick rip in the twisties and it pulls nice and smooth through all the gears. Sounds great. Baffle out btw. 2 1 Link to comment Share on other sites More sharing options...
kilo3 Posted May 1, 2021 Share Posted May 1, 2021 Could someone take a picture top down and from the rear? I'm about to pull the trigger but want to see how far it sticks out. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted May 1, 2021 Supporting Member Share Posted May 1, 2021 @kilo3 - The Scorpion is actually very unobtrusive, I like it a lot. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
