thruster8999 Posted March 25, 2015 Share Posted March 25, 2015 First video sounds horrorable. Second one much better. Link to comment Share on other sites More sharing options...
rockman Posted March 26, 2015 Share Posted March 26, 2015 Took delivery of my FJ-09 today. I measured the chain slack as set by the dealer/factory at 20mm total range (up plus down from static) while on center stand. The chain sounds normal when spinning rear wheel in neutral on the center stand. Shifting seems fine, too. Link to comment Share on other sites More sharing options...
falcophil Posted March 29, 2015 Share Posted March 29, 2015 The mechanic at the dealers went over my bike with me when they handed it over, he told me the chain is tighter than normal on purpose due to the set up on the bike. he said it should be 5-15mm and that once you sit on the bike unlike most bikes it actually increases the clearance. can only presume this is due to the postion of the sprockets and pivot point of swinging arm. Link to comment Share on other sites More sharing options...
Guest rszk Posted March 30, 2015 Share Posted March 30, 2015 ^^Interesting^^. I checked my tension on the centerstand, then sat on the bike off the center stand and the tension was higher...Verified by my son checking tension. Link to comment Share on other sites More sharing options...
Premium Member wessie Posted March 30, 2015 Premium Member Share Posted March 30, 2015 The mechanic at the dealers went over my bike with me when they handed it over, he told me the chain is tighter than normal on purpose due to the set up on the bike. he said it should be 5-15mm and that once you sit on the bike unlike most bikes it actually increases the clearance. can only presume this is due to the postion of the sprockets and pivot point of swinging arm. I think you need to have a chat with @Cruizin about the veracity of the wisdom from a dealer technician... This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
robb Posted April 8, 2015 Share Posted April 8, 2015 Several others have noticed more freeplay with the suspension sacked on this model, which I assume is why the spec is also tighter. Wouldnt want the chain to skip a tooth and wad up in the cases coming off a little hump or taking your girlfriend on a ride on humpday! Someone needs to yank a shock to get to the bottom of all of these inquiries. Link to comment Share on other sites More sharing options...
Premium Member wessie Posted April 9, 2015 Premium Member Share Posted April 9, 2015 Several others have noticed more freeplay with the suspension sacked on this model, which I assume is why the spec is also tighter. Wouldnt want the chain to skip a tooth and wad up in the cases coming off a little hump or taking your girlfriend on a ride on humpday! Someone needs to yank a shock to get to the bottom of all of these inquiries.Alternatively, stop fretting, follow the manual and just ride the bloody thing. If it ain't broke, don't go "fixing" it... This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
bobdog Posted April 9, 2015 Share Posted April 9, 2015 Is that an auto-oiler on the bike in the video? Info please 2015 Grey FJ09 with a few tweaks, 2007 HD Street Glide - Good Bike + Good Friends = Good Day. Link to comment Share on other sites More sharing options...
kiwi Posted April 9, 2015 Share Posted April 9, 2015 My bike had it first service yesterday. The mechanic (non factory) was horrified at the lack of chain tension. It shifts and runs more smoothly now that he's adjusted it. Link to comment Share on other sites More sharing options...
