Source for Wheel Weights
nhchris
Where do you guys get replacement  clip-on wheel weights for the FJ blurple rims with the center ridge?
Yamaha OEMs then at $7.50 USD per weight.
Any other reliable and cheaper sources out there?
Thanks, cb
1968 Triumph Bonneville 650
1971 Norton Commando Roadster
2002 Harley 1200 Sportster
2003 Honda ST 1300
2016 FJ 09
5 hours ago, kmev said:
I switched from wheel weights to Dyna-beads years ago. Much less hassle than balancing with lead, and you'll never lose a bead on the road. 1 ounce in front tires, 2 ounces in rear.
Interesting! Never heard of them but they peaked my interest. Out of curiosity have you ever seen a wheel with dyna beads run on a wheel balancer? Am curious to know if it would consider it balanced.
I have not. My only testing is about 50,000 miles at all sorts of speeds on a few different bikes and tires, and I never had any odd vibrations. I was skeptical at first, too, but they seem to be widely used in all sorts of applications.
The only drawback is when changing tires - if they get on the floor they can be a mess. The positive is that I have reused beads between tires.
I found that the filtered Schraeder valves (as recommended) do not work on motorcycles - they are too long and make the tire go flat. After I removed the filtered valves and went back to standard schraeders I have not had any problems.
I use motion pro stick on weights, balance a new-to-me rim once, tape with gaffers tape, and it's done. Doesn't get balanced again unless I go to a tire that still ships with heavy spots (my usual tires don't). Never an issue with balance or losing weights street or track.
