stevengau Posted January 15, 2019 Share Posted January 15, 2019 I installed an SUV fog lights https://www.amazon.com/gp/product/B07DWQ9DNZ/ref=ppx_yo_dt_b_asin_title_o05__o00_s00?ie=UTF8&psc=1 It is 60W per piece with 6000 LM output per single unit. The lights are very bright and I rode it around for an hour test ride with the lights on with no problem. I asked some of my riding friends around, some say it is ok, some say it is too much which may damage my bike's charging system. I have very few knowledge of the power of FJ. Can anyone give comments on this? Link to comment Share on other sites More sharing options...
Premium Member runnerhiker Posted January 16, 2019 Premium Member Share Posted January 16, 2019 I have a 90 watt heated liner that I use in the winter, it is not a problem for the charging system on my GT. That would be like 1-1/2 of your lights, my guess is that you are ok if you don't also have other high wattage pieces like a heated liner. Edit add: I could not find the watt spec for the charging system, but I found that the plug for the optional heated seat is 7.5 amps or 90 watts, so you should be fine with a 120 watt light system. 2019 Tracer 900 GT Niwot CO USA Link to comment Share on other sites More sharing options...
stevengau Posted January 20, 2019 Author Share Posted January 20, 2019 Thank you. Link to comment Share on other sites More sharing options...
