littlebruv Posted August 7, 2019 Share Posted August 7, 2019 Can these inflators be plugged into the bikes power socket or does the amps of the inflator exceed the sockets fuse rating Link to comment Share on other sites More sharing options...
Premium Member wessie Posted August 7, 2019 Premium Member Share Posted August 7, 2019 3 hours ago, littlebruv said: Can these inflators be plugged into the bikes power socket or does the amps of the inflator exceed the sockets fuse rating No. Yamaha has a 2A fuse on that socket with very thin wiring. It's for charging a phone or satnav. As the battery is easily accessible, just use the crocodile clips. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted October 19, 2019 Premium Member Share Posted October 19, 2019 On 3/3/2019 at 8:34 AM, piotrek said: I use Stop&Go... fits neatly under the seat (red arrow). Need to cut off the plastic divider to make the under-seat compartment larger/continuous. Thank you @piotrek ! Done. 1 Link to comment Share on other sites More sharing options...
kaia Posted November 5, 2019 Share Posted November 5, 2019 I keep a Moto Pumps Air Shot under the seat. It's super small, more than powerful enough for any flat - and comes with all the cables needed. Personally, I install the pigtail off of the battery and tuck under the seat. Then, i can trim down the Air Shot kit to just the other end of the pigtail, nixing the cheesy alligator clips & the 12v adapter. Non-affiliated link: Air Shot — MotoPumps - The Best 12v Inflators on the Planet The MotoPumps Air Shot Inflator is the smallest, lightest, full performance... 1 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted November 6, 2019 Premium Member Share Posted November 6, 2019 I have the exact same pump but its branded as Dynaplug https://www.amazon.com/Dynaplug-Ultra-Compact-Volt-Inflator/dp/B01F6I4222/ref=pd_rhf_ee_s_bmx_1_5/136-2280354-7629562?_encoding=UTF8&pd_rd_i=B01F6I4222&pd_rd_r=b0cec0f3-e7d3-42bc-a199-705b1bd98243&pd_rd_w=lyIvy&pd_rd_wg=jFU2f&pf_rd_p=267fe2c3-d92f-4dfc-ac6e-0821d9326e4f&pf_rd_r=ZKPSSAR6XBFQ258YNJN6&psc=1&refRID=ZKPSSAR6XBFQ258YNJN6 Link to comment Share on other sites More sharing options...
flyfifer Posted November 8, 2019 Share Posted November 8, 2019 Piotrek, thanks for your post away back in page 1. After a bit of dilly dallying I decided to cut out the Plastic Cross Member to connect the space under the pillion seat Lock Mount to the "official" under seat space. My compressor (like the orange RAC one above) now fits (just) under the lock bar and the pillion seat goes on -- with a wee bit of pressure. (If the screwdriver handle mount was cut off the pillion seat underside the pillion seat would be an easier fit.) Thanks Piotrek for the idea. 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted November 8, 2019 Supporting Member Share Posted November 8, 2019 13 hours ago, flyfifer said: ...After a bit of dilly dallying I decided to cut out the Plastic Cross Member to connect the space under the pillion seat Lock Mount to the "official" under seat space. Good idea indeed... credit goes to peeps from an old thread on here. 🙂 Link to comment Share on other sites More sharing options...
