vespadaddy Posted March 15, 2015 Share Posted March 15, 2015 Does anyone know if the accessory plug has enough juice to run a heated jacket liner? I know the bike is supposed to make enough juice, but I'm wondering if the wires that supply the accessory plug are of a sufficient gauge to supply adequate power. Or do I need to just hook the heated clothing pigtail straight to the battery, as I have done on previous bikes. Link to comment Share on other sites More sharing options...
Premium Member clint Posted March 15, 2015 Premium Member Share Posted March 15, 2015 Does anyone know if the accessory plug has enough juice to run a heated jacket liner? I know the bike is supposed to make enough juice, but I'm wondering if the wires that supply the accessory plug are of a sufficient gauge to supply adequate power. Or do I need to just hook the heated clothing pigtail straight to the battery, as I have done on previous bikes.Definitely not. 2 amps max on the accessory plug. Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
leedavis Posted March 15, 2015 Share Posted March 15, 2015 I installed an aftermarket 12V/15A accessory socket wired to the battery on the right side of the dash where the FJ has a hole for one. I think I used a Bikemaster socket (I got it for a different project that didn't happen) and there are others. Link to comment Share on other sites More sharing options...
vespadaddy Posted March 16, 2015 Author Share Posted March 16, 2015 I assume you then had heavier gauge wires that ran straight to the battery terminals. Is this correct? Link to comment Share on other sites More sharing options...
leedavis Posted March 17, 2015 Share Posted March 17, 2015 I assume you then had heavier gauge wires that ran straight to the battery terminals. Is this correct?Yes, a heavier wire (maybe 14 guage) to the battery terminals with a 15A inline fuse. I've used it to power heated jacket and gloves. Link to comment Share on other sites More sharing options...
