Premium Member upshift Posted April 1, 2019 Premium Member Share Posted April 1, 2019 Had a funny situation today. Was out this morning for a 30 minute ride and noticed partway that my turn signals weren't working. When I got to my destination, I checked to see if it was just the dash indicators not working but none of the actual turn lights were lighting up. After a couple of hours sitting, I drove it home, thinking I'd need to be using hand signals, but all the signals worked just fine. Also working fine a couple of hours later when I rode again. Anyone else experienced this little hitch? If so, what was the cause? Thanks. Link to comment Share on other sites More sharing options...
skipperT Posted April 1, 2019 Share Posted April 1, 2019 What had you taken apart or modified most recently in the bike? -Skip Link to comment Share on other sites More sharing options...
Premium Member upshift Posted April 1, 2019 Author Premium Member Share Posted April 1, 2019 15 hours ago, skipperT said: What had you taken apart or modified most recently in the bike? -Skip Nothing, Skip - did an oil change just before that ride but that's been it for this year. The only things that was different was that it was stored outside for two night, whereas I always have it under cover at home. It didn't rain overnight but there was a bit of water on it from the neighbour's sprinkling system when I started it up. Not sure if that might have interrupted the circuit temporarily or not. Thanks for ringing in on this. Link to comment Share on other sites More sharing options...
skipperT Posted April 2, 2019 Share Posted April 2, 2019 16 hours ago, upshift said: Nothing, Skip - did an oil change just before that ride but that's been it for this year. The only things that was different was that it was stored outside for two night, whereas I always have it under cover at home. It didn't rain overnight but there was a bit of water on it from the neighbour's sprinkling system when I started it up. Not sure if that might have interrupted the circuit temporarily or not. Thanks for ringing in on this. Sure. If it’s all good now, but wasn’t before then a bad connection somewhere is most likely. Water really shouldn’t affect anything that easily as I’ve ridden mine through downpours with no problems. All you can really do at this point is to remove fairings and check all the connections at the signals. Trace the turn signal housing wires along the bars to see where they disappear into a bundle of plugs and make sure it’s secure. Verify the turn signal switch is properly located on the bars and snug. One time I did find a plug from a switch housing that wasn’t “clicked” into place by the factory and it was causing some weird electrical issues (not on an FJ/MT though). Water inside the switch housing could also cause your symptoms. Good luck. -Skip Link to comment Share on other sites More sharing options...
norfolkphil Posted April 2, 2019 Share Posted April 2, 2019 I had a similar thing happen on my bike around a year ago. All fine riding along, then no indicators. Got home, turned the bike off, and on starting it again all was working. I presume I was a bit ham fisted cancelling a turn signal, and had 'confused' the lighting relay which had become stuck mid position. Turning the power off reset the relay, and then all was fine. Never happened again after that one time. Phil 1 Link to comment Share on other sites More sharing options...
Premium Member upshift Posted April 3, 2019 Author Premium Member Share Posted April 3, 2019 Thanks, @skipperT and @norfolkphil. I'm hoping it was a one-off but, if it happens again, I'll try Phil's relay reset and Skip's sleuthing approach. Much appreciated, fellas. 1 Link to comment Share on other sites More sharing options...
Clicknow Posted October 31, 2020 Share Posted October 31, 2020 The same thing happened to me,my problem was the ingition key was not turned fully to the on position even tho bike would still start. regards graham Link to comment Share on other sites More sharing options...
Dodgy Knees Posted October 31, 2020 Share Posted October 31, 2020 My indicators stopped working once. Pulled over, turned key off and on and all good again... I put it down to the 21st century. 🤷🏻♂️ 1 Link to comment Share on other sites More sharing options...
angrygirafe Posted October 31, 2020 Share Posted October 31, 2020 For me, this usually just means I need to clean the contacts at the switch. I have to do my high beam switch pretty much once a year. Could be your issue is as simple as that. Link to comment Share on other sites More sharing options...
MiPe Posted January 10, 2021 Share Posted January 10, 2021 (edited) This happens if you don`t turn the key completely. The key can stay like 5-10 degrees before the ON, the ignition and lights work but the turn signals won`t. It resulted to be a feature if you don`t oil the keyhole, the key gets stuck a bit. Just put oil in to the keyhole. That was the case in my bike and worked well after that. Edited January 10, 2021 by MiPe Link to comment Share on other sites More sharing options...
Denideul Posted January 10, 2021 Share Posted January 10, 2021 Never put oil or grease in a keyhole, that would stick dust and so on in the lock and with the time damage it. Instead you must put graphite.😄 2 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 10, 2021 Supporting Member Share Posted January 10, 2021 49 minutes ago, Denideul said: Never put oil or grease in a keyhole, that would stick dust and so on in the lock and with the time damage it. Instead you must put graphite.😄 I use this stuff on keyholes and throttle and clutch cables. Dri-Slide Bike Aid Film Lubricant | 10% ($2.20) Off! Dri-Slide Bike Aid Film Lubricant creeps into the smallest spaces. This... 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
MiPe Posted January 11, 2021 Share Posted January 11, 2021 Thanks. I'll try graphite / dry lubricant and ask about that from Yamaha Center because they added and also recommended light oil into the keyhole. It worked well but didn't think long term effects at that point. Link to comment Share on other sites More sharing options...
