Danielblue Posted October 18, 2020 Share Posted October 18, 2020 Had to take the seat bracket off to get the power wire. 4 allen bolts. left the seat locking mechanism attached. you can try to unbolt it, but mine is either glued or welded in place, likely glued and you don't need to fully remove it, just move it aside. 1 Link to comment Share on other sites More sharing options...
Danielblue Posted October 20, 2020 Share Posted October 20, 2020 Heated seat has me sitting a bit higher on the bike than the stock seat. Not a huge difference, but the low position of the adjustment now feels about equal to where the high position was before going to the heated comfort seat Link to comment Share on other sites More sharing options...
SuperMax Posted October 20, 2020 Share Posted October 20, 2020 3 minutes ago, Danielblue said: Heated seat has me sitting a bit higher on the bike than the stock seat. Not a huge difference, but the low position of the adjustment now feels about equal to where the high position was before going to the heated comfort seat I thought I am the only one experiencing this with the heated seat Moreover, I have observed that on the low setting, the front of the seat is not that firmly locked in place, there is definitely a play to the front. Has been therefore forced to set it to the high position (but no major difference to the low one in terms of overall height) Link to comment Share on other sites More sharing options...
ilanr1 Posted February 26, 2023 Share Posted February 26, 2023 (edited) Hi , I have managed to buy a heated seat without the switch to operate it ... There are 4 wires at the plug. It should be lighted orange at start = off , first push low heat = green , second push high heat = red. Next push orange again = off. The colors of the wires are white , green , brown , red. If i push the switch what is the connection on the wires ?. Thanks Edited March 3, 2023 by ilanr1 Link to comment Share on other sites More sharing options...
