Chris Pearson Posted April 16, 2019 Share Posted April 16, 2019 Hi I've purchased some ohlins fork springs and oil does anybody know the correct way to go about changing these? Ie how to get all old oil out also when you measure the air gap do you have the spring in and is the fork compressed or extended when measuring? Thanks Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted April 17, 2019 Supporting Member Share Posted April 17, 2019 This video is a good source for many things fork related and what you need is all there (near the beginning and then toward the end). Are these Ohlins springs drop-in, i.e. can you re-use OE spacers? There are several sources for springs, but some will require you to buy or modify/cut existing spacers. Have fun. 1 Link to comment Share on other sites More sharing options...
captainscarlet Posted April 17, 2019 Share Posted April 17, 2019 10 hours ago, Chris Pearson said: Hi I've purchased some ohlins fork springs and oil does anybody know the correct way to go about changing these? Ie how to get all old oil out also when you measure the air gap do you have the spring in and is the fork compressed or extended when measuring? Thanks I would recommend this video by Dave Moss: Just ignore the stuff about changing seals and the compression circuit. I have just done exactly the job that you are about to do and you can read about it here: CS 1 Link to comment Share on other sites More sharing options...
skipperT Posted April 17, 2019 Share Posted April 17, 2019 (edited) Oil level is always set without springs, fork reassembled, and collapsed. -Skip Edited April 17, 2019 by skipperT 2 Link to comment Share on other sites More sharing options...
koth442 Posted April 17, 2019 Share Posted April 17, 2019 8 hours ago, skipperT said: Oil level is always set without springs, fork reassembled, and collapsed. -Skip Our guru has spoken. '15 FJ09 Link to comment Share on other sites More sharing options...
skipperT Posted April 18, 2019 Share Posted April 18, 2019 Where’s the”eye roll” button? 1 Link to comment Share on other sites More sharing options...
