Seetth Posted June 16, 2020 Share Posted June 16, 2020 (edited) 5 minutes ago, BBB said: @Seetth, that code is “intake air pressure sensor”, shown in the list above. It probably means that you disturbed something during your throttle body synch, or left something off. It may be worth clearing the code and if it comes back, going back under the tank and checking around where you did the work. I will have to take apart the bike again to double check specially the sensors, how do we clear the codes on the dashboard I already try the link that was posted somewhere on this forums but the link doesn't work, thanks for answer I had to remove this one for access more easy the cap in that throttle body maybe that is my issue funny that the bike runs great Edited June 16, 2020 by Seetth Link to comment Share on other sites More sharing options...
BBB Posted June 16, 2020 Share Posted June 16, 2020 Some pages from the manual for you. More detail on code 13. You’ll see that the failsafe is for the bike to run properly. 1 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
BBB Posted June 16, 2020 Share Posted June 16, 2020 Enter diagnostic mode, then go to code 62 to clear the history. 2 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Seetth Posted June 16, 2020 Share Posted June 16, 2020 Thank you guys I will do that tomorrow Link to comment Share on other sites More sharing options...
Seetth Posted June 16, 2020 Share Posted June 16, 2020 I forgot to connect one of the sensors, thank you guys for the help, now everything its fine. 1 Link to comment Share on other sites More sharing options...
