cammy Posted June 10, 2019 Share Posted June 10, 2019 anyone had trouble with the 2017 tracer 900 with the front end doing it s own thing when liggage'd up at the rear? any help would be great thanks people! Link to comment Share on other sites More sharing options...
Premium Member superfist Posted June 24, 2019 Premium Member Share Posted June 24, 2019 On 6/10/2019 at 6:04 PM, cammy said: anyone had trouble with the 2017 tracer 900 with the front end doing it s own thing when liggage'd up at the rear? any help would be great thanks people! A few people have noted it in the past. Usual recommendations are to crank up the rear shock preload and raise the forks in the triple-tree by 5 to 10mm. This puts a little more of the weight bias back to the front wheel. The spend money fixes are to get new springs weighted for rider + gear that you normally carry (minimal investment). A rear shock rebuild/revalve is the middle ground with a new shock/fork cartridges being the big spend. I have a 2015, and turning up the rear preload, raising the forks in the triple tree and raising the rear compression/rebound to a 1/4 turn off of max setting fixed the light/flighty front end feeling. It also doesn't do the rocking horse on fast sweepers anymore, though it still doesn't feel planted when pushed. 230lbs with gear, for reference. Link to comment Share on other sites More sharing options...
