edgarjessop12 Posted June 21, 2019 Share Posted June 21, 2019 Hi, my dash Red warning light for oil level and temperature on my 900 GT ( UK Model ) started to come on after riding off first thing in the morning after about half a mile, I would stop and pull over and after about 15 seconds it would go out, set off again and half a mile later the very same thing. Then can ride all day and it never happens again, even if I stop for a few hours it does not come on again. Then the next morning the very same thing Even though I know it is not low on oil and the temperature is correct. I frightens me and I have to stop. Then as I said is all right all day. Cheers Edgar Jessop . Link to comment Share on other sites More sharing options...
BBB Posted June 21, 2019 Share Posted June 21, 2019 Is your oil level at the very top of the sight glass? Mine prefers it to be up there rather than slightly lower down. As you haven’t mentioned it, and it also makes no sense why it only does it at the start of the ride, it is unlikely to be the coolant level, but worth a glance at the levels in the filler bottle anyway, just in case. 2 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
M.G Posted June 23, 2019 Share Posted June 23, 2019 Hi, because of the distance ridden involved I doubt it’s anything too dramatic and certainly sounds electrical - what coolant temp is your display showing when light illuminated? I’m assuming it’s still under warranty and breakdown cover - I would be at the door of your local dealer and politely point out that you are going to drink all their coffee until they have looked at it !! I’m lucky that my dealer is spot on and always seems to prioritise warranty work. 1 Link to comment Share on other sites More sharing options...
Premium Member motopumps Posted June 24, 2019 Premium Member Share Posted June 24, 2019 I experienced the same thing after the first oil change. I had the oil half way up the sight glass vs nearly to the top. Topping off the oil fixed the issue. Rob 3 1 Link to comment Share on other sites More sharing options...
bigorangecntry07 Posted June 25, 2019 Share Posted June 25, 2019 I believe the cause of this is oil not up to operating temps yet. 1 Link to comment Share on other sites More sharing options...
Premium Member rustyshackles Posted June 25, 2019 Premium Member Share Posted June 25, 2019 I’ve had the same experience as bigorangecntry07. Always in cool or cold temperatures. I asked a Yamaha tech and he said it’s likely oil temp/viscosity related. Have the bike checked out if you are uncomfortable. 1 IBA Member #59800 3 Nations Brewing Mug Club #100 Link to comment Share on other sites More sharing options...
edgarjessop12 Posted June 26, 2019 Author Share Posted June 26, 2019 Thanks a lot guys. It is very strange. And it has not done it since I asked about it. Hahahaha The oil looks like it is on the very top line in the sight glass, and as it has only happened first thing in the morning the temperature is not even up to normal........ but all looks ok now !!!!! If it happens again I will put a 1/4 pint of oil in !!!!!!!!!! and if it still did it straight round to the Dealer. Thanks again. Link to comment Share on other sites More sharing options...
Pupsi Posted June 26, 2019 Share Posted June 26, 2019 (edited) Don't put in more oil than is required. Otherwise you will have unnecessary pressure and oil will be spit out into the airbox. After a change of oil and oil filter you need to run the engine for a few minutes (and then wait for a couple of minutes to allow the oil to settle) before you check the sight glass. This for two reasons: the oil needs to be warm ( as it expands when warm) and also because the new oil filter will 'consume' some oil. Another point: see that the oil you are using is suitable for the ambient temperature you are in. In a cold country, 10W-30 oil would be much better than, for example, 20W-50 oil Edited June 26, 2019 by Pupsi To be clearer 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 26, 2019 Supporting Member Share Posted June 26, 2019 4 hours ago, edgarjessop12 said: Thanks a lot guys. It is very strange. And it has not done it since I asked about it. Hahahaha The oil looks like it is on the very top line in the sight glass, and as it has only happened first thing in the morning the temperature is not even up to normal........ but all looks ok now !!!!! If it happens again I will put a 1/4 pint of oil in !!!!!!!!!! and if it still did it straight round to the Dealer. Thanks again. Do you get your bike up to operating temperature before riding? Or just start it and go? I start mine and let it run while putting on jacket, ear plugs, helmet and gloves. 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
