Ahmed Posted October 24, 2019 Share Posted October 24, 2019 Make sure to get the original one though if you don't want to end up with flimsy ones. Link to comment Share on other sites More sharing options...
v1nn1e Posted October 25, 2019 Share Posted October 25, 2019 Just mounted mine up this morning. It's the Ultimate Addons handlebar clamp with three-prong attachment. Just long enough to go between the bar clamps and for the Universal Smartphone holder not to foul the top of them. Even in portrait orientation, it doesn't obscure the instruments. I dug out an old USB cigarette lighter charger that has one built-in cable but then discovered that cable was broken, so using as a SatNav the phone died on my 20 minutes in to the ride. I'll try again this evening using the raw USB port and cable but this is not weatherproof. What are folks using for USB charging that uses the accessory socket and is weatherproof too...? Link to comment Share on other sites More sharing options...
tojjer Posted October 25, 2019 Share Posted October 25, 2019 (edited) 50 minutes ago, v1nn1e said: I'll try again this evening using the raw USB port and cable but this is not weatherproof. What are folks using for USB charging that uses the accessory socket and is weatherproof too...? Well, I use one of these usb cigarette lighter adaptors and a rather cheap and nasty plastic bag to weatherproof it. It has been out in all kinds of weather and not had any leaks yet. Made a small hole in the bottom to pass the power cable through, then taped it up. What I should've done, ( and may yet ) is use a longer thinner plastic bag so that where the cable goes into it, can be bent over so any water would have to travel uphill to get into it ( if that makes sense ) It's like its own condom!! Edited October 25, 2019 by tojjer 1 Link to comment Share on other sites More sharing options...
Dodgy Knees Posted October 25, 2019 Author Share Posted October 25, 2019 I wasn't happy charging from the bikes socket on the go so use a battery bank from tank bag. Link to comment Share on other sites More sharing options...
tojjer Posted October 25, 2019 Share Posted October 25, 2019 I did that above as a temporary measure when we went to France. I've not remembered to do anything about it since June, and it has been in some heavy downpours since. Link to comment Share on other sites More sharing options...
