firemanjim Posted March 24, 2015 Share Posted March 24, 2015 Anyone know what wire in harness is the system ground? Looking to wire in some running lights. Know what it is on Suzukis but not Yamaha. Link to comment Share on other sites More sharing options...
Premium Member ULEWZ Posted March 25, 2015 Premium Member Share Posted March 25, 2015 Anyone know what wire in harness is the system ground? Looking to wire in some running lights. Know what it is on Suzukis but not Yamaha. I need a little more information to help you. There are tons of wiring harnesses. Please pick a circuit, tell me what color wires are in there, and I will help identify the ground. A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
firemanjim Posted March 25, 2015 Author Share Posted March 25, 2015 Most bikes have a common system ground and it will be same color all throughout bike. Looking for that up by headlights. Link to comment Share on other sites More sharing options...
robb Posted March 28, 2015 Share Posted March 28, 2015 There are 2 blank grey colored plugs under the windshield and windshield cover which are prewired 12 Volts plugs designed for accessories like this. Link to comment Share on other sites More sharing options...
wordsmith Posted February 22, 2018 Share Posted February 22, 2018 There are 2 blank grey colored plugs under the windshield and windshield cover... Do you need to use a connector to get the power, can you just push a 12 gaugue wire in there and tape it on tight? Or buy this and maybe it will fit? http://www.cycleterminal.com/mt-series-090.html 2 pin MT .090 - 2.3mm Male and Female locking connector Male half only Male MT090-2 $3.15 each Appreciate any direction here... FWIW - I cut the grey terminals off and simply soldered new leads onto the cut wires, then put a short length of heat-shrink tube over each joint. This powered my two (2) front conspicuity hi-viz LEDs. Wordsmith - a 1939 model. Previously owned a 2019 Tracer 900 GT, Midnight Black. Now enjoying a 2020 Yamaha MT-09 SP. Happily living near the sea in Redland Bay, SE Queensland, Australia. Link to comment Share on other sites More sharing options...
