jdavis Posted December 25, 2019 Share Posted December 25, 2019 When I had my lightbar, I used these. 2x 2"in 25mm-50mm Mount Bracket Clamp For LED Light Bull Bar HID Holder Mounting ... Link to comment Share on other sites More sharing options...
mingo Posted December 27, 2019 Share Posted December 27, 2019 I have a 6" (15 cm) Rigid LED lightbar which I had mounted on my former SuperTenere and will now mount it to my Tracer. Do you think the optional lighting accessory socket hidden behind the windshield can handle the load? The wiring harness for the lightbar has no relays, I had it plugged into a Fuzeblock, so it doesn't draw a lot. Anyone know what the accessory light fuse is rated at? the owner's manual says it's located next to the left side panel, but does not mention how many amps the fuse is, I have to remove the panel to see it. My lightbar is similar to this one but in black. SR-Series - SR-Series PRO | Rigid Industries The SR-Series PRO LED Light Bars provide a sleek, low profile... 1 Link to comment Share on other sites More sharing options...
Premium Member keithu Posted December 27, 2019 Premium Member Share Posted December 27, 2019 The size is fine. If anything the Tracer is better suited to tall people than short due to the seat height. Although there are plenty of shorties around here. 😀 2 Link to comment Share on other sites More sharing options...
TheBigG Posted December 29, 2019 Author Share Posted December 29, 2019 On 12/27/2019 at 9:03 PM, mingo said: I have a 6" (15 cm) Rigid LED lightbar which I had mounted on my former SuperTenere and will now mount it to my Tracer. Do you think the optional lighting accessory socket hidden behind the windshield can handle the load? The wiring harness for the lightbar has no relays, I had it plugged into a Fuzeblock, so it doesn't draw a lot. Anyone know what the accessory light fuse is rated at? the owner's manual says it's located next to the left side panel, but does not mention how many amps the fuse is, I have to remove the panel to see it. My lightbar is similar to this one but in black. SR-Series - SR-Series PRO | Rigid Industries The SR-Series PRO LED Light Bars provide a sleek, low profile... I think it is a 30V lightbar, right? In tis case it draws 2.5 Amps which is pretty low. Link to comment Share on other sites More sharing options...
harraseeket Posted March 2, 2020 Share Posted March 2, 2020 yes i hate looking at if not through those add on deflectors for windscreen. if you really want to get out of the wind ( like i do ) get a givi 2139 t . i'm 6' , run it in low position on side roads so i am looking over the screen top but wind hitting 2" down from top of helmet, and on high position on the highway which pretty much sends wind over the top of my helmet 1 Link to comment Share on other sites More sharing options...
TheBigG Posted April 25, 2020 Author Share Posted April 25, 2020 Now with Shad SH35 cases they are very solid and nice looking but the problem is that I can't lock them. The key won't rotate. I don't know why... 1 Link to comment Share on other sites More sharing options...
BBB Posted April 25, 2020 Share Posted April 25, 2020 Check the number on the key matches the number on the lock surface? Or the latch itself is not closed properly? Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 25, 2020 Supporting Member Share Posted April 25, 2020 1 hour ago, TheBigG said: Now with Shad SH35 cases they are very solid and nice looking but the problem is that I can't lock them. The key won't rotate. I don't know why... Lift the carrying handle and try to turn the key, the locking mechanism tab fits into the carrying handle, if it doesn't fit in there the tab might be just a little bit bent. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
roadwarrior Posted August 22, 2020 Share Posted August 22, 2020 The bike looks great! The first thing I do to any bike is get rid of the abomination that is the sub finder. I suggest replacing with a Motodynamic sub-fender eliminator and integrated tail-light. Link to comment Share on other sites More sharing options...
Soullancer Posted August 22, 2020 Share Posted August 22, 2020 (edited) Nice looking bike! Isn't the passenger seat bag a little clumsy to get it off quick? And one thing I noticed, or is it just me? You sit back quite alot on the saddle, while I always sit against the front of the tank lol. Edited August 22, 2020 by Soullancer Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted August 22, 2020 Supporting Member Share Posted August 22, 2020 2 hours ago, Soullancer said: And one thing I noticed, or is it just me? You sit back quite alot on the saddle, while I always sit against the front of the tank lol. Probably due to his height, he mentioned that he is 6'-3", I am 6'-1" and sit at the rear of the seat as well. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
TheBigG Posted August 22, 2020 Author Share Posted August 22, 2020 (edited) 5 hours ago, Soullancer said: Nice looking bike! Isn't the passenger seat bag a little clumsy to get it off quick? And one thing I noticed, or is it just me? You sit back quite alot on the saddle, while I always sit against the front of the tank lol. Yes! It is due to my height...an my legs Also, the seat is wider and confortable at the back. The straps that holds the bag innplace are elastic so it is easy to remove it butbyou have to take the rear seat down. Edited August 22, 2020 by TheBigG Link to comment Share on other sites More sharing options...
