Supporting Member betoney Posted November 6, 2019 Supporting Member Share Posted November 6, 2019 6 hours ago, norcal616 said: Part kit is on National Backorder till 11/21/19... Even tho it's listed as "in stock" .. Got an "I'm sorry" email with the option to cancel order or wait... I picked to wait 🙄... Like @coachluciano said, its worth the wait. Not only is the clutch pull effort reduced but the slipper function is nice if you ride a little more aggressively. Approach a corner, kick down a gear and set corner speed (no brakes necessary) and power through, no driveline shock or wheel hop. When you get the parts, search the forum for the slipper clutch thread, I did a write-up with a few specific notes to watch for. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
norcal616 Posted November 6, 2019 Share Posted November 6, 2019 @coachluciano, @betoney I have seen the threads for years, just now got the chance to order the kit... I can wait- winter is here till April 🙄 1 1 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
ilanr1 Posted November 9, 2019 Share Posted November 9, 2019 Hi , can you share the Brembo part number that you are talking about ? Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted November 9, 2019 Author Premium Member Share Posted November 9, 2019 5 hours ago, ilanr1 said: Hi , can you share the Brembo part number that you are talking about ? They were delivered yesterday. 1 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
ilanr1 Posted November 20, 2019 Share Posted November 20, 2019 Hi , is there anything new with this project ?. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted November 20, 2019 Author Premium Member Share Posted November 20, 2019 5 hours ago, ilanr1 said: Hi , is there anything new with this project ?. Got it mounted - fits great. The slave is supposed to be here this week. Then I can measure for the length of hydraulic line and get that ordered from Spiegler. I'll post picts when the slave is here 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted November 20, 2019 Supporting Member Share Posted November 20, 2019 Are you going to use a hydraulic pressure switch for the clutch safety switch? He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted November 20, 2019 Author Premium Member Share Posted November 20, 2019 5 minutes ago, roadrash83 said: Are you going to use a hydraulic pressure switch for the clutch safety switch? That is the intended plan. I have a few to try as soon as I get the hydraulic line and slave together. 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted November 20, 2019 Author Premium Member Share Posted November 20, 2019 Finally got the slave today. Fits perfectly where it should. Next up, buy the hydraulic line and see if things play well together. 1 1 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted November 20, 2019 Author Premium Member Share Posted November 20, 2019 I will admit, snaking a Spiegler line through the “clutch path” has me concerned. Have conceded to Old Man Winter here in NY so the bike is parked in its winter resting place. Will take the tank and air box off this weekend and get a good idea for routing the line. Need to do that anyways to get the new brake lines installed 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted November 23, 2019 Author Premium Member Share Posted November 23, 2019 Found this after some exhaustive searching. Should be here maybe next week. The hydraulic switch has me on the fence and this will eliminate any doubt. Looks like a simple 3mm tap into the handle to screw down the post and the rest is plug and play. Find out soon enough. Have the bike apart and can finally pull the cable and get measuring for the hydraulic line. 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted November 23, 2019 Author Premium Member Share Posted November 23, 2019 1 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted November 25, 2019 Author Premium Member Share Posted November 25, 2019 Ordered the custom hydraulic line from Spiegler today. They were awesome to deal with on the phone. Fingers crossed that not only did I measure properly, but all goes together as hoped. 1 1 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted November 29, 2019 Author Premium Member Share Posted November 29, 2019 Line came today. Dry fit was perfect. Glad I measured everything properly. Was a $98 gamble. Get some fluid in it this weekend and finally have the answer to this whole project. 1 1 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
ilanr1 Posted December 2, 2019 Share Posted December 2, 2019 Ok , waiting for your update !!! Link to comment Share on other sites More sharing options...
