Winter Projects
- ECU flash
- strip, clean, lube and reassemble brakes
- check head bearings
- TB synch
- attempt to put netting in the pannier lids to hold loose stuff
  • Thumbsup 2
On 11/15/2019 at 10:44 AM, skipperT said:
-Pull the exhaust cam and loosen the valves. TB sync.
-install the Allballs steering head bearings I bought 3 years ago.
-hopefully install F&R suspension upgrades that I buy on Black Friday/Cyber Monday.
-Install the Honda CB handlebar “weights” inside my bars, see if there’s a difference.
-Order a new masterlink for the chain, remove it and clean thoroughly.
that’s all I can think of at the moment.
-Skip
Don't bother with the weights in the handlebars. I filled my with BBs as I had read people have done this to cut down on vibration. I t does nothing. Interestingly..........it doesn't take that many BBs to pack them full. This is my only area of motorcycle expertise.
Edited by Guest
I never bothered with all the other ideas- main culprit is the front sprocket- replace with a plain jane one that don't have a rubber damper...
10 hours ago, BBB said:
- ECU flash
Is that going to happen or already done? About to tear into the bike this weekend and the ECU is heading to Vcyclenut for a re-flash to correct for the Scorpion slip-on and the block-off plates.
Going to happen, for the same two reasons: exhaust and block-off plates. I’m just getting a few more rides in before winter gets a grip, then off it will go.
18 hours ago, BBB said:
  • attempt to put netting in the pannier lids to hold loose stuff
This can also be pretty useful if installed into the lid of a top-box.   Usually, when opened, stuff wants to fall out, but a bit of netting can and will hold stuff in the lid even when raised to a near-vertical position.
  • re-flash ECU (slip-on installed)
  • replace handlebar (something with better sweep)
  • replace heated grips (if can't salvage Oxfords)
  • replace heated gear controls (failed in a downpour)
  • replace fork oil and grease fork seals
  • inspect and grease head bearing
  • grease swing arm and relay arm bearings
  • replace tires
  • replace wheel bearing seals and spacers
  • replace brake caliper pins (stainless)
  • synchronize throttle bodies
  • replace rear brake pads (EBC HH)
  • replace brake lines (...bonus track)
Will also explore fabricating an aluminum perch over the pillion seat for RotopaX container(s), and other uses. Something that bolts to the pillion grab handle mount points. Dragging my feet on this one for two winters now.
  • Thumbsup 5
@piotrek - That's quite a list, it should keep you busy for a while.
Curious about the wheel bearings and spacers.  Do the spacers wear out?  Whenever I have the wheels off I always pull the dust seal from the bearings and pack in a little more fresh grease, not sure what the lifespan of a wheel bearing is though.
The bearings stay. I will be looking to replace the seals only. The spacers and seals kinda wear together, so will replace the lot. Inexpensive, and will keep me off the couch. 😉
...on second thought @betoney... I think I may leave the spacers alone. Front right 'spacer' (also the ABS sensor housing) made me rethink this.
Where do you get the "plain jane" ones?
At the local motorcycle shop... Yamaha 525 sized sprocket and pick your teeth count... 16T is stock count, I went with 15T...
Here is a link for Revzilla:
  • Thumbsup 3
So I've had my 2015 for about 2 weeks.  Got it with 24k miles.  Since this is new to me, I'll be crawling through all the scheduled maintenance items just to make sure everything caught up, tight, and right.
- Forks going to DMr Performance for revalve and springs.
- ECU to 2WDW.
- Check and shim valves as needed.
- APM adjust.
- Trim handlebars by 2 inches.
- Wrap or plasti-dip the luggage lids.
If funds and time are still available by riding season:
- LED signals.
- K-Tech Rear shock
- Rizoma or Renthal handlebars for more sporty configuration if the OEM bar trim doesn't satisfy.
- Sargent seats.
That should keep me busy!
Cheers!
  • Thumbsup 2
  • Like 1
-Skip
I wanted to do the Honda handlebar weight thing too. They always seemed to work well. Let me know how you go.
@piotrek - This is something that may interest me as well.  When you say sweep, are you talking about how the bars angle back toward the rider?
I have a set of gilles bar risers installed that are set as far back towards me as they will go but I feel as though I'm still 'reaching' slightly if that makes sense.  Maybe slightly narrower bars would be an option for me?  Thoughts?
53 minutes ago, dazzler24 said:
When you say sweep, are you talking about how the bars angle back toward the rider?...
Yes. Something a bit angled back and maybe narrower (can cut to suit), but without sacrificing rise. I have SW-Motech Barback risers at the moment (30mm up and 22mm back).
  • Thanks 1
