BugsInTeeth Posted November 25, 2019 Share Posted November 25, 2019 if a guy did the lowering links as suggested, wouldn't it be a good idea to drop the forks in the triples 3/4 of an inch also ? BugsinTeeth........ "Peace is that time when everyone stands around reloading" . . . . Thomas Jefferson Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 25, 2019 Supporting Member Share Posted November 25, 2019 I sure would. Anytime you alter the ride height it affects the steering geometry. A lot of FJ/Tracer owners raise the fork in the clamps 10-15mm, lowering the front end which sharpens steering. My shock has ride height adjustment so I raised the rear about 5mm and raised the forks about 5-7mm, same end result. 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted November 25, 2019 Supporting Member Share Posted November 25, 2019 2 hours ago, BugsInTeeth said: if a guy did the lowering links as suggested, wouldn't it be a good idea to drop the forks in the triples 3/4 of an inch also ? When I had my lowering links in I did just that. 1 Link to comment Share on other sites More sharing options...
Torquil Posted November 25, 2019 Author Share Posted November 25, 2019 Sounds like lowering links is the way to go then. I’ll definitely have a look at that then. Thanks for all your advice. 1 Link to comment Share on other sites More sharing options...
