magnatic Posted May 20, 2020 Share Posted May 20, 2020 On 1/2/2020 at 10:59 PM, norcal616 said: Change out the front sprocket for a plain jane one not a rubber noise dampen one... What front sprocket do you recommend? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted May 20, 2020 Supporting Member Share Posted May 20, 2020 16 minutes ago, magnatic said: What front sprocket do you recommend? FJ-09 | Sprockets & Chain Kits Sprocket Center is dedicated to being the world's premium provider of... ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
magnatic Posted May 20, 2020 Share Posted May 20, 2020 Thank you. Link to comment Share on other sites More sharing options...
Clicknow Posted May 20, 2020 Share Posted May 20, 2020 On 1/14/2020 at 12:30 AM, norcal616 said: Mine didn't either, but the left foot peg was more noticeable than right side, but I knew it was chain related vibrations... A chain is ment to ride on its inner rollers not the actual outside chain plates which is producing the odd bass like clunky vibrations due to the "rubber noise damping ring"... and I also found the "rubber damping ring" kinda masked the chain "feeling" I normally feel or sense if it's tight/lose/binding/or the alignment is off... Hi I did this today as I had a small amount of buzz in my pegs and yes it has worked no buzz now,until about 80mph great, I did not replace sprocket I just removed the damper and reinstalled,thanks norcal6 regards graham Link to comment Share on other sites More sharing options...
