vrex Posted January 6, 2020 Share Posted January 6, 2020 I ordered a replacement battery for my 2015 FJ, the Yuasa YTZ10S which is advertised by all sellers as being compatible with the bike. Upon trying to install it I find that the terminals are backward from what is needed, i.e. the positive terminal needs to be on the top LEFT corner to fit the wiring harness. Is this a known issue, or am I going crazy at last? The latter seems possible . . . Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 6, 2020 Supporting Member Share Posted January 6, 2020 6 minutes ago, vrex said: I ordered a replacement battery for my 2015 FJ, the Yuasa YTZ10S which is advertised by all sellers as being compatible with the bike. Upon trying to install it I find that the terminals are backward from what is needed, i.e. the positive terminal needs to be on the top LEFT corner to fit the wiring harness. Is this a known issue, or am I going crazy at last? The latter seems possible . . . Turn it over, it installs on its side. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
vrex Posted January 6, 2020 Author Share Posted January 6, 2020 I smite my forehead. Thanks. 1 Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted January 6, 2020 Supporting Member Share Posted January 6, 2020 @vrex - As @betoney mentions, the battery lays on its side, with the ‘top’ pointing towards the right side of the bike. Kudos to you for realizing something was wrong before hooking up the battery cables. There have been several folks here who didn’t notice the polarity issue, and the end result is inevitably a couple of blown fuses. Glad you sorted it out! 1 Link to comment Share on other sites More sharing options...
