nhchris Posted January 7, 2020 Share Posted January 7, 2020 What does the GT Owners Manual say re start procedure? 1 1968 Triumph Bonneville 650 1971 Norton Commando Roadster 2002 Harley 1200 Sportster 2003 Honda ST 1300 2016 FJ 09 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 8, 2020 Supporting Member Share Posted January 8, 2020 20 minutes ago, nhchris said: What does the GT Owners Manual say re start procedure? The only mention of the switch I could find is this, nothing mentioned on preference for shutting the bike off. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member Kenny A. Posted January 8, 2020 Author Supporting Member Share Posted January 8, 2020 I don't use the kill switch all the time,but as littlebruv says,its easier to reach than the key. Anyway bike was collected last night,so it's now back at the dealer. 2019 900 GT, 1969 Honda S90 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 8, 2020 Supporting Member Share Posted January 8, 2020 6 hours ago, Kenny A. said: I don't use the kill switch all the time,but as littlebruv says,its easier to reach than the key. Anyway bike was collected last night,so it's now back at the dealer. Please keep us posted on the outcome to this issue. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member Kenny A. Posted January 8, 2020 Author Supporting Member Share Posted January 8, 2020 3 hours ago, betoney said: Please keep us posted on the outcome to this issue. Will do. 2019 900 GT, 1969 Honda S90 Link to comment Share on other sites More sharing options...
skipperT Posted January 8, 2020 Share Posted January 8, 2020 Sounds like the start solenoid/relay assy is sticking. Glad your dealer is stepping up. -Skip Link to comment Share on other sites More sharing options...
mingo Posted January 8, 2020 Share Posted January 8, 2020 Yamaha uses the same switch on several bikes. I had it on my SuperTenere without issues. Eager to hear how it's resolved. Link to comment Share on other sites More sharing options...
Supporting Member Kenny A. Posted January 11, 2020 Author Supporting Member Share Posted January 11, 2020 Right then. Got bike back from dealer last night. The cause of all this is NOT starter/kill switch. I fitted a pair of Denali DRL's/Indicators, but did NOT connect them up. I know very little about bike electrics,so asked a biker guy who stays along the road from me if he would connect them up for me. He said no problem. Turns out the cause of the starter not going off is when ignition is switched,DRL's come on (fine), but they are also sending a permanent live feed straight to the starter,hence it keeps turning. l don't know how they are DRL's are connected,I wasn't there when this was done. Dealer checked starter/kill switch,and all relays.(all o.k.). He has now disconnected DRL's,and taped all the wires up,the indicators are o.k. Everything is now perfect. So what I thought was a warranty claim, has turned out to be an expensive botch job by this guy,who I thought knew about electrics. The final bill which included a service (oil + brake fluid change) was £192 !!! OUCH !! 1 2019 900 GT, 1969 Honda S90 Link to comment Share on other sites More sharing options...
Toddtr Posted January 11, 2020 Share Posted January 11, 2020 Now you should edit your title and apologize for jumping to conclusions about Yamaha having starter issues. Nice one Yamaha 👍 not “Nice one a Yamaha 👎” Until you know for sure, don’t be a d.... 1 1 Link to comment Share on other sites More sharing options...
BBB Posted January 11, 2020 Share Posted January 11, 2020 Thanks for the update @Kenny A.. Good to know that it wasn’t a starter issue per se. I wired my DRLs from the spare accessory wiring points that are behind the windscreen as they are switched live. 1 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 11, 2020 Supporting Member Share Posted January 11, 2020 @Kenny A. - Glad you got the issue resolved and are back on the road. Like @BBB mentioned, behind the screen are several available 12v switched auxiliary power plugs, I hardwired my GPS and Denali DRL's into those plugs. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member Kenny A. Posted January 13, 2020 Author Supporting Member Share Posted January 13, 2020 Done! 👍 Thanks. 1 2019 900 GT, 1969 Honda S90 Link to comment Share on other sites More sharing options...
mingo Posted January 22, 2020 Share Posted January 22, 2020 On 1/13/2020 at 9:30 AM, Kenny A. said: Done! 👍 Thanks. You should edit your first post to indicate it was not a warranty issue but a botched lighting installation. Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted January 22, 2020 Premium Member Share Posted January 22, 2020 On 1/11/2020 at 7:15 AM, Toddtr said: Until you know for sure, don’t be a d.... Little harsh? 2 Link to comment Share on other sites More sharing options...
BBB Posted January 22, 2020 Share Posted January 22, 2020 38 minutes ago, 1moreroad said: Little harsh? Yep, definitely. But not outside our acceptable behaviour boundaries. Most people play nice on this forum and take a moment to post helpful replies 😎 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
