Premium Member keithu Posted January 8, 2020 Premium Member Share Posted January 8, 2020 Has anyone added a deflector to the top of their V-Stream touring windshield? I have their large touring shield, and at 6'3" with a long torso it's still not quite tall enough for me. I'm trying to decide if I should just add a deflector to what I have rather than try something else. I'm interested to hear what works or doesn't. Link to comment Share on other sites More sharing options...
tinkerfreak Posted January 11, 2020 Share Posted January 11, 2020 I have one of these on my Parabellum windscreen and it works a treat, needed a little extra deflection to get the pressure off my one shoulder. If you are thinking of a superior protection for your window, the multigravailable Clip-on Puig visor is the solution. It is a multirregular visor tha - Motoplastic PUIG PUIG presents three multiregulable visors with two fixation systems: fixed... Cheers 1 Link to comment Share on other sites More sharing options...
Premium Member keithu Posted January 11, 2020 Author Premium Member Share Posted January 11, 2020 11 hours ago, tinkerfreak said: I have one of these on my Parabellum windscreen and it works a treat, needed a little extra deflection to get the pressure off my one shoulder. Something like that is what I'm considering. I'm curious if anyone else has tried this on the V-Stream specifically. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 11, 2020 Supporting Member Share Posted January 11, 2020 31 minutes ago, keithu said: Something like that is what I'm considering. I'm curious if anyone else has tried this on the V-Stream specifically. I don't have an exact answer referencing the V-Stream, I thought I would share this. Motorcycle Adjustable Clip On Windscreen Windshield Extension Spoiler Wind Deflector Adjustable Lockable Plus and Mini Size Description:The Screen is supplied with extension arms and Double Hinges... At $50 it is $120 cheaper than the MRA "Touring" version. I have the smaller MRA "Sport" version and use it on occasion, the effects are noticeable but not dramatic. I might try this brand as the mini version is 1" taller and 1" wider than my current MRA Sport. The important thing to consider with these spoilers is the width of your screen to make sure the mount posts fit. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
BBB Posted January 12, 2020 Share Posted January 12, 2020 14 hours ago, keithu said: Something like that is what I'm considering. I'm curious if anyone else has tried this on the V-Stream specifically. I don’t have your windscreen either, but I’m sure a deflector would work for you. The reason being that I notice a big difference from just altering the angle of the deflector. I have other, taller windscreens that work okay, but they are then in my eye line which I find annoying. I can use a shorter screen when there is a deflector on the top, angled upwards, that keeps my view ahead clear and reduces wind noise to acceptable levels in the motorway/highway speed range. 2 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Premium Member keithu Posted January 12, 2020 Author Premium Member Share Posted January 12, 2020 19 hours ago, betoney said: The important thing to consider with these spoilers is the width of your screen to make sure the mount posts fit. The V-Stream is pretty wide at the top, but I was also looking at some deflectors with a single center mount. That should work with virtually any width and shape. 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 12, 2020 Supporting Member Share Posted January 12, 2020 19 minutes ago, keithu said: The V-Stream is pretty wide at the top, but I was also looking at some deflectors with a single center mount. That should work with virtually any width and shape. Most of the deflectors that I have seen are available in 2 sizes with the smaller versions needing 8-9" width on the top of the screen to mount and the larger ones needing around 11" width for the mount arms. I haven't used the single center mount versions but yes, they should work on any shield. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Willie17FJ-09 Posted March 4, 2020 Share Posted March 4, 2020 I found the deflector makes a big difference on the light tinted v-stream touring. Link to comment Share on other sites More sharing options...
