ilanr1 Posted January 14, 2020 Share Posted January 14, 2020 (edited) Hi , i have noticed a knocking sound from the left shock , my internals are completely Andreanni not stock ones.. No leaking issue all is dry. I can definitely hear it over small bumps on the road. I'm going to disassemble it , what should i check ? Or in other words what could be defective ?. Thanks Edited January 14, 2020 by ilanr1 Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted January 14, 2020 Supporting Member Share Posted January 14, 2020 @ilanr1Are you sure the knocking sound is not coming from the floating brake rotors? He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
ilanr1 Posted January 14, 2020 Author Share Posted January 14, 2020 I'm not touching the brakes and when i hit an obstacle like a pavement i can hear a knocking sound from the left shock Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 14, 2020 Supporting Member Share Posted January 14, 2020 1 hour ago, ilanr1 said: Hi , i have noticed a knocking sound from the left shock , my internals are completely Andreanni not stock ones.. Did the issue start when you installed the cartridges or have you had the cartridges installed for awhile? ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
ilanr1 Posted January 14, 2020 Author Share Posted January 14, 2020 No it just started lately. I have the Andreanni cartridges for 3 years with no issues. Maybe it's the inner bushing ? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 14, 2020 Supporting Member Share Posted January 14, 2020 14 minutes ago, ilanr1 said: No it just started lately. I have the Andreanni cartridges for 3 years with no issues. Maybe it's the inner bushing ? That is what I was going to suggest. Keep us posted with your findings. Good luck. 👍 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
skipperT Posted January 14, 2020 Share Posted January 14, 2020 3 hours ago, ilanr1 said: No it just started lately. I have the Andreanni cartridges for 3 years with no issues. Maybe it's the inner bushing ? Definitely a possibility. I just replaced mine when I found a small patch of brass showing through the Teflon material. the other possibility I’ve read about is the springs and spacers knocking into the outer fork tube. Someone solved that issue with some Orings. -Skip Link to comment Share on other sites More sharing options...
ilanr1 Posted January 14, 2020 Author Share Posted January 14, 2020 Ok , i will try with the bushings and see how it goes. Will update soon. Thanks Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted January 14, 2020 Supporting Member Share Posted January 14, 2020 @ilanr1 - Have you seen this thread? Link to comment Share on other sites More sharing options...
ilanr1 Posted January 15, 2020 Author Share Posted January 15, 2020 Thanks i'll check it. Link to comment Share on other sites More sharing options...
