draco_1967 Posted April 13, 2021 Share Posted April 13, 2021 31 minutes ago, dazzler24 said: Good to hear that you're almost there. I'm out for a ride right now..stopped for a bite....but IIRC the info was in one of the many instructions that came with the McCruise. I'll check with this post and get back to you if you haven't found the answer by then. Aha! I found it. It's in the installation guide, not the diagnostic and setup guide. Page 47. Thanks again, and enjoy your ride! 1 Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted April 13, 2021 Supporting Member Share Posted April 13, 2021 Huzzah! Had to be in there somewhere 🙂 Quote One thing I found on mine is the wiring colors were a little different. Yes, mine were different from the cct drawing that I had as well and I think it was Tony who said that they have had a few different cables suppliers over time and they can be a little different from each other. But as long as you use your trusty meter on them, like you did, then Robert is the brother of one of your parents. 🙂 Quote Thanks again, and enjoy your ride! No problem, and I did. My lunch spot and reply location earlier today...... the hills were calling. 2 Link to comment Share on other sites More sharing options...
draco_1967 Posted April 13, 2021 Share Posted April 13, 2021 I went in this morning and reprogrammed the controls, so it should be SET/DEC and RES/ACC to match the labeling on the Tenere switch. I also set it so it remembers the on/off state of the cruise. Now, if the cruise is on when I turn the bike off, it will automatically turn on when I turn the bike on next time. 1 Link to comment Share on other sites More sharing options...
