Premium Member 2and3cylinders Posted September 28, 2020 Premium Member Share Posted September 28, 2020 Those pairs of holes retain a bracket on each side that attach via sump pan bolts. I believe you can download the installation instructions on Twisted throttle and elsewhere. Link to comment Share on other sites More sharing options...
flyfifer Posted September 28, 2020 Author Share Posted September 28, 2020 Or there is one like this which looks a very similar design to the SWMotech offering. Engine Chassis Guard Skid Plate For YAMAHA FZ09 FJ09 MT-09 Tracer 900 GT XSR900 For YAMAHA XSR900... Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted September 28, 2020 Supporting Member Share Posted September 28, 2020 1 hour ago, flyfifer said: Or there is one like this which looks a very similar design to the SWMotech offering. Engine Chassis Guard Skid Plate For YAMAHA FZ09 FJ09 MT-09 Tracer 900 GT XSR900 For YAMAHA XSR900... I like how in the "item description" there's this - Material: Steel Then further down under "Description" there's this - Material: High Quality of Aluminum Alloy Which leads me to - The skid plate's like a box a chocolates..... you never know what you gonna get! 2 1 Link to comment Share on other sites More sharing options...
flyfifer Posted September 28, 2020 Author Share Posted September 28, 2020 Maybe there's s free magnet to identify which metal is which ! It does look worth a punt at under £70. 1 Link to comment Share on other sites More sharing options...
flyfifer Posted September 28, 2020 Author Share Posted September 28, 2020 This seller wants a few pounds more and like the previous seller makes it clear there are no instructions. They do however include an image with some good dimensions information for the keen DIY enthusiast 🤔😉 SKID PLATE Engine Bash Guard for Yamaha Tracer 900 XSR900 MT09 FJ09 15-19 BK U3 1x Moto Black Front Brake... Link to comment Share on other sites More sharing options...
Clegg78 Posted September 28, 2020 Share Posted September 28, 2020 (edited) 2 hours ago, flyfifer said: Or there is one like this which looks a very similar design to the SWMotech offering. Engine Chassis Guard Skid Plate For YAMAHA FZ09 FJ09 MT-09 Tracer 900 GT XSR900 For YAMAHA XSR900... Keep in mind, this is the same kind that I just used that crumpled like wet cardboard on a rock. After buying the real-deal SW-Motec protector, these are NOTHING a like other than shape. Also the black one I purchased didn't fit that well... took some tweaking to get on. The SW Motec fit perfectly. You get what you pay for in this case it seems. I saved ~ $100 on the cheaper black Ebay guard plate... but it cost me $1300 in damages, towing, rental truck to get home. Note these are all made of aluminum, no steel options in this design that I could find. Edited September 28, 2020 by Clegg78 4 2 Link to comment Share on other sites More sharing options...
Clegg78 Posted September 28, 2020 Share Posted September 28, 2020 7 minutes ago, flyfifer said: This seller wants a few pounds more and like the previous seller makes it clear there are no instructions. They do however include an image with some good dimensions information for the keen DIY enthusiast 🤔😉 SKID PLATE Engine Bash Guard for Yamaha Tracer 900 XSR900 MT09 FJ09 15-19 BK U3 1x Moto Black Front Brake... This is the exact one I had that failed so epically. Buyer beware. The alloy these use is shit. 3 Link to comment Share on other sites More sharing options...
Clegg78 Posted September 28, 2020 Share Posted September 28, 2020 15 minutes ago, flyfifer said: Maybe there's s free magnet to identify which metal is which ! It does look worth a punt at under £70. Nope... Higher end 7000 series alloys (ex: 7075) are marginally more magnetic than 6061 or lower end alloys that the black ones may be... but you cant tell from any non industrial gauss level. (ie: MRI machines can pull 7075 objects across a room...) Link to comment Share on other sites More sharing options...
flyfifer Posted September 29, 2020 Author Share Posted September 29, 2020 😁😁😁 Link to comment Share on other sites More sharing options...
flyfifer Posted September 29, 2020 Author Share Posted September 29, 2020 Joking aside re the material response to magnets 🤔🤔. The negative comments on similar bash plates are noted. SWMotech ---- or DIY, it will be ! Link to comment Share on other sites More sharing options...
flyfifer Posted September 29, 2020 Author Share Posted September 29, 2020 Clegg, are you saying that the fixing brackets of the cheap option were not steel ? What crumpled the brackets or plate ? Link to comment Share on other sites More sharing options...
Clegg78 Posted September 29, 2020 Share Posted September 29, 2020 (edited) 6 hours ago, flyfifer said: Clegg, are you saying that the fixing brackets of the cheap option were not steel ? What crumpled the brackets or plate ? The brackets on the eBay one and the actual sw-motec are steel, the eBay ones were far sketchier quality though, and didn’t line up right. The plates of both are aluminum though. I believe the brackets are designed to crush on a strong enough hit in some way to not damage the crank case bolts. the brackets did bend, all 3 of them , but the plate itself failed epically as well. Edited September 29, 2020 by Clegg78 Link to comment Share on other sites More sharing options...
flyfifer Posted September 29, 2020 Author Share Posted September 29, 2020 I am not sure any bash plate is going to stop that kind of damage to an oil sump ! As you say the SWMotec type design, using the sump bolts for mounting, must require some sacrificial crumpling to avoid damaging the bolts. I am not sure how much maths after market suppliers put into their designs. The Givi bash plate offering does use mounting points that I suspect would stand a shock load better --- as ever price comes into play. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted September 30, 2020 Premium Member Share Posted September 30, 2020 9 hours ago, flyfifer said: I am not sure any bash plate is going to stop that kind of damage to an oil sump ! As you say the SWMotec type design, using the sump bolts for mounting, must require some sacrificial crumpling to avoid damaging the bolts. I am not sure how much maths after market suppliers put into their designs. The Givi bash plate offering does use mounting points that I suspect would stand a shock load better --- as ever price comes into play. It's more than just price its weight accessibility and then the looks I'm going to reinforce the bottom of my sw-motech skid plate somehow but I never go off road or hop curbs so I'm in no hurry one of these days Twisted Throttle had a sale early this year on the SW Motech skid plate 90 bucks shipped I couldn't pass it up! 2 Link to comment Share on other sites More sharing options...
flyfifer Posted October 1, 2020 Author Share Posted October 1, 2020 SW-Motech also offer an item called Front Spoiler. This cannot be fitted with the Engine Guard It's not clear to me why they would have two items to protect similar areas. The Front Spoiler is however more complex in construction and twice the price of the Engine Guard. Link to comment Share on other sites More sharing options...
