tojjer Posted February 25, 2020 Author Share Posted February 25, 2020 I will, thank you Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted February 26, 2020 Supporting Member Share Posted February 26, 2020 4 hours ago, betoney said: When you order the tank ring, make sure to order the 110 EVO ring. If I remember correctly, they recommend a different ring, (307, 308 maybe?) but that one has the bag sitting 1" or more above the tank surface. I believe this is a post that clarifies the part numbers for the 'correct' ring to use. For the record, I bought this part number TRT.00.640.11001/B (110) which is the 'low' version. 1 1 Link to comment Share on other sites More sharing options...
tktplz Posted February 27, 2020 Share Posted February 27, 2020 (edited) Mine is the SW-Motec City Bag with the 308, higher ring it suggests for it. It's 15 liters and holds everything, plus water bottles, etc. I did want a bit bigger bag that can hold a days worth of stuff and room in case ya buy something out on the road. Edited February 27, 2020 by tktplz 2 Ain't no fun when the rabbit gets the gun! Link to comment Share on other sites More sharing options...
mike Posted February 27, 2020 Share Posted February 27, 2020 (edited) I have been using the City bag for six years on three bikes. This bag has done at least 50,000 miles and still looks new and latches securely. You do pay more for these bags but this has been the best quality of any bag I have used in the past. I got creative and modified a tank ring from my old Triumph Tiger 1050 to work on the GT and everything works well. If there is a taller ring, that will be the one you need. I had to shim the latching hardware away from the bottom of the bag to get it to work on the standard height ring so the extra height ring will be needed. Edited February 27, 2020 by mike Link to comment Share on other sites More sharing options...
Dodgy Knees Posted February 27, 2020 Share Posted February 27, 2020 The deeper tank ring doesn't look great without bag but you do get used to it. Bit like an ashtray. Not on subject but...how do those 2 bikes compare.? Link to comment Share on other sites More sharing options...
hardwareguy2068 Posted February 27, 2020 Share Posted February 27, 2020 Also use the SW Motech Engage bag....It is a fantastic bag and looks outstanding on the FJ! Link to comment Share on other sites More sharing options...
tojjer Posted February 27, 2020 Author Share Posted February 27, 2020 Thanks to everyone for replying. SW it is I think. Link to comment Share on other sites More sharing options...
Premium Member keithu Posted February 27, 2020 Premium Member Share Posted February 27, 2020 On 2/25/2020 at 6:11 AM, chitown said: Added a $20 ring setup and a piece of cutting board for stiffness to a strap on Cortech in the gear closet. Been using it for four years and works great. After decades of other mounting systems I'm all ring now. Any pics of this? I'm intrigued. Link to comment Share on other sites More sharing options...
flyfifer Posted February 27, 2020 Share Posted February 27, 2020 Have a look at this Givi part. Givi sell it as a spare so that should the locking system on your Givi Tanlock bag fail --- you can replace it inexpensively rather than have to buy a new bag. You can of course buy the item and fit it to any tankbag to convert it to tanklock. Givi ZT480R New Replacement "Tanklock" Lock & Release Flange Mechanism This is the part that screws to... The "common" method is to buy a couple of really cheap polyprop kitchen cutting boards. Cut them so one fits neatly inside your selected ancient (magnetic?) tank bag. Cut the other board, probably a bit smaller, centre the two parts and drill them so you can mount the Givi flange. Sandwich the tank bag with the boards. Hot wire the mounting holes through the bag. Screw the Flange and BagSandwich together. Voila a tanklock bag. There was a video someplace but I could not find it -- hence all the words. 1 Link to comment Share on other sites More sharing options...
flyfifer Posted February 27, 2020 Share Posted February 27, 2020 Predictably I found A Video. Not the full Cutting board conversion but it shows the principle. Link to comment Share on other sites More sharing options...
flyfifer Posted February 27, 2020 Share Posted February 27, 2020 If we had categories for threads on here finding stuff would be easier. Link to comment Share on other sites More sharing options...
BBB Posted February 27, 2020 Share Posted February 27, 2020 22 minutes ago, flyfifer said: If we had categories for threads on here finding stuff would be easier. Do you mean, in the forum entry page (where we have lots of different sections) or in the search function (where you can click on extra search functions and refine by date, member etc)? 1 1 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
flyfifer Posted February 27, 2020 Share Posted February 27, 2020 (edited) Off Topic but --- Sub Divisions. For example-- Technical -- servicing, electrics, problems.etc Accessories --- Luggage, Racks, Seats.etc Clothing/Helmets/Boots. Trip Reports/Accomodation. Tyres. The other forums I use all split up stuff. Edited February 27, 2020 by flyfifer Link to comment Share on other sites More sharing options...
BBB Posted February 27, 2020 Share Posted February 27, 2020 @flyfifer. Like this, or different? Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
flyfifer Posted February 27, 2020 Share Posted February 27, 2020 (edited) General is far too inclusive. Gear is far too General. And it's still off Topic Edited February 27, 2020 by flyfifer Link to comment Share on other sites More sharing options...
