Clicknow Posted March 13, 2020 Share Posted March 13, 2020 Hi can anyone give me there recommendations for a good quality replacement chain and sprockets for the GT please regards graham Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 13, 2020 Supporting Member Share Posted March 13, 2020 11 minutes ago, Clicknow said: Hi can anyone give me there recommendations for a good quality replacement chain and sprockets for the GT please regards graham I always use their Superlite Sprockets and a DID VX chain. You can buy everything as a kit, chain cut to correct size. Yamaha Tracer 900 / 900GT | Sprockets & Chain Kits | Sprocket Center Sprocket Center is dedicated to being the world's premium provider of... 4 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted March 13, 2020 Premium Member Share Posted March 13, 2020 6 minutes ago, betoney said: I always use their Superlite Sprockets and a DID VX chain. You can buy everything as a kit, chain cut to correct size. Yamaha Tracer 900 / 900GT | Sprockets & Chain Kits | Sprocket Center Sprocket Center is dedicated to being the world's premium provider of... Based on recommendations from this website, I used the same site except an EK chain and screw link. https://sprocketcenter.com/motorcycle-chains/ek-chain-srx-2-master-link-screw-link-select-pitch-size-2713.html 2 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 13, 2020 Supporting Member Share Posted March 13, 2020 14 minutes ago, 1moreroad said: Based on recommendations from this website, I used the same site except an EK chain and screw link. https://sprocketcenter.com/motorcycle-chains/ek-chain-srx-2-master-link-screw-link-select-pitch-size-2713.html No issues with the EK Screw master link? 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
kmev Posted March 14, 2020 Share Posted March 14, 2020 37 minutes ago, betoney said: No issues with the EK Screw master link? I installed an EK screw link with a new chain before I rode from Wisconsin to the Arctic Ocean last summer. Install was super easy and haven't had a problem - including on the Dempster Highway. I'll buy it again. 4 1 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 14, 2020 Supporting Member Share Posted March 14, 2020 3 minutes ago, kmev said: I installed an EK screw link with a new chain before I rode from Wisconsin to the Arctic Ocean last summer. That is one hell of an achievement. 😎👍 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
RandyN Posted March 14, 2020 Share Posted March 14, 2020 13 hours ago, betoney said: I always use their Superlite Sprockets and a DID VX chain. You can buy everything as a kit, chain cut to correct size. Yamaha Tracer 900 / 900GT | Sprockets & Chain Kits | Sprocket Center Sprocket Center is dedicated to being the world's premium provider of... That is a good price! I just paid about $185 for a whole setup with Vortex sprockets and DID VX chain. I think if you stick with bigger name products you probably can't go too wrong. Haven't put them on yet though. 18,500 and still looks good. What kind of mileage is everyone getting? 1 Link to comment Share on other sites More sharing options...
Clicknow Posted March 15, 2020 Author Share Posted March 15, 2020 Yamaha MT09 Tracer GT DID Gold X-Ring Heavy Duty Chain & JT Sprocket Kit Set Yamaha MT09 Tracer GT. JT sprockets are made using only the best... thanks for your replys,does the above look ok?and is this the right kit for the tracer GT? kind regards graham Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 15, 2020 Supporting Member Share Posted March 15, 2020 3 hours ago, Clicknow said: thanks for your replys,does the above look ok?and is this the right kit for the Tracer GT? Its listed for the Tracer GT but curious why it has an 118 link chain?? Stock is 110 link. If you are skeptical about the seller or want to guarantee that you get the correct parts, use the link that I provided above. "(525 Pitch 118 Link Chain,16 Tooth Front & 45 Tooth Rear) 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Clicknow Posted March 15, 2020 Author Share Posted March 15, 2020 Betoney thank you,so I can just take 8 links of with my chain breaker? And all would be good? regards graham Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 15, 2020 Supporting Member Share Posted March 15, 2020 1 minute ago, Clicknow said: Betoney thank you,so I can just take 8 links of with my chain breaker? And all would be good? regards graham Yes, if you have the tools, then go for it. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
candave650 Posted March 15, 2020 Share Posted March 15, 2020 i believe the GT has a longer swingarm than the standard hence the more links 1 1 Link to comment Share on other sites More sharing options...
Clicknow Posted March 15, 2020 Author Share Posted March 15, 2020 Hi again, just counted the pins and I have 118 so the above should be correct? regards 2 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 15, 2020 Supporting Member Share Posted March 15, 2020 @candave650 and @Clicknow OK, I was thinking FJ09, thanks for the correction. 👍 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted March 15, 2020 Supporting Member Share Posted March 15, 2020 1 hour ago, betoney said: Its listed for the Tracer GT but curious why it has an 118 link chain?? Stock is 110 link. If you are skeptical about the seller or want to guarantee that you get the correct parts, use the link that I provided above. "(525 Pitch 118 Link Chain,16 Tooth Front & 45 Tooth Rear) Wasn’t 110 the stock length for the first-gen FJ? With the extended swingarm length on the newer GT, that 118 may well be right. 2 Link to comment Share on other sites More sharing options...
