stumpy Posted March 26, 2020 Share Posted March 26, 2020 Ok...I can be cheap some times and I could be taking one up the hoop tonight. I bought these cheap turn signals and the relays for LED'S and all I get is a white DLR and a mix of white and amber turn signals flashing...is there a know fix for LEDs on a fj09 or are these just shite? I dont know how to include a small vid Link to comment Share on other sites More sharing options...
BBB Posted March 26, 2020 Share Posted March 26, 2020 How many wires to your new purchase? Any instructions? You should have a common ground, a running light (DLR) and a turn signal. Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
stumpy Posted March 27, 2020 Author Share Posted March 27, 2020 (edited) 27 minutes ago, BBB said: How many wires to your new purchase? Any instructions? You should have a common ground, a running light (DLR) and a turn signal. And you would be correct. 3 wires. When I hold the ground to a battery and hold the DLR wire to the positive, the white light comes on. When I put the turn signal wire on the positive with the ground on negative...I get nothing. When I have DRL + and ground - and add the wire for the amber it goes completely amber flashing with no white DLR. No so much when i am connected to the bike connector.. obviously the bike does something a little different when you hit the signal button. I am no electrical genius there for I am stumped. These are the little buggers Edited March 27, 2020 by stumpy Link to comment Share on other sites More sharing options...
Mvich Posted March 27, 2020 Share Posted March 27, 2020 Using your description it seems the DRL's expect to be hot at all times. When you select a turn signal to power it's logic tells it to flash amber and cancel the white. So wire the DRL's to be powered all the time and attach the current turn signal wire for the amber. 2 Link to comment Share on other sites More sharing options...
stumpy Posted March 27, 2020 Author Share Posted March 27, 2020 57 minutes ago, Mvich said: Using your description it seems the DRL's expect to be hot at all times. When you select a turn signal to power it's logic tells it to flash amber and cancel the white. So wire the DRL's to be powered all the time and attach the current turn signal wire for the amber. it definitely appears that way. that's why i did the test on the battery to confirm my suspicion. Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted April 2, 2020 Supporting Member Share Posted April 2, 2020 On 3/27/2020 at 10:21 AM, stumpy said: And you would be correct. 3 wires. When I hold the ground to a battery and hold the DLR wire to the positive, the white light comes on. When I put the turn signal wire on the positive with the ground on negative...I get nothing. When I have DRL + and ground - and add the wire for the amber it goes completely amber flashing with no white DLR. No so much when i am connected to the bike connector.. obviously the bike does something a little different when you hit the signal button. I am no electrical genius there for I am stumped. These are the little buggers I'm on the hunt for something like this too. How have you found these @stumpy? Bright enough? Link to comment Share on other sites More sharing options...
stumpy Posted April 2, 2020 Author Share Posted April 2, 2020 9 hours ago, dazzler24 said: I'm on the hunt for something like this too. How have you found these @stumpy? Bright enough? Disappointed in the amber turn signal brightness because it shares space with the white led's. Wouldn't recommend them. Stick with solid amber ones that are 3wire for the fronts. My 2 wire rears are pretty good because all the led's are amber. 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 2, 2020 Supporting Member Share Posted April 2, 2020 9 hours ago, dazzler24 said: I'm on the hunt for something like this too. How have you found these @stumpy? Bright enough? @dazzler24 I have tried several 'cheaper' LED turn signals over the years and have been disappointed with all of them, the saying 'you get what you pay for' certainly holds true. If you want BRIGHT, compact and indestructible, there is only one - X-Arc. X-Arc Lights - the brightest LED Brake lights, turn signals, tail lights 2 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted April 2, 2020 Supporting Member Share Posted April 2, 2020 You can't go wrong with X_Arc lights! They bright as hell, solid aluminum and will survive a nuclear blast👍 1 1 He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted April 2, 2020 Supporting Member Share Posted April 2, 2020 4 hours ago, stumpy said: Disappointed in the amber turn signal brightness because it shares space with the white led's. Wouldn't recommend them. Stick with solid amber ones that are 3wire for the fronts. My 2 wire rears are pretty good because all the led's are amber. @stumpy - Thanks stumpy. I was afraid, but expected, that you might say that. I do like the idea of a white running light separating the colour from the amber turn signal. I can't help but think that there will be those on the road that see an amber light (solid or blinking) and still think it's a turn signal defeating the very thing that they are intended for - more safety. But that maybe just me?! Hmm more thought and reseach required for me I'm thinking. 4 hours ago, betoney said: @dazzler24 I have tried several 'cheaper' LED turn signals over the years and have been disappointed with all of them, the saying 'you get what you pay for' certainly holds true. If you want BRIGHT, compact and indestructible, there is only one - X-Arc. X-Arc Lights - the brightest LED Brake lights, turn signals, tail lights @betoney - Yes, I remember that you have advocated for these in other posts and they do seem to be of top quality. For me here in the Land down under it would cost around AU$410 (US$250) landed for 2 pairs of DRL/indicators. Ouch! I agree that you do get what you pay for it's just that, well....400 plus clams for blinkers - ouch! What price for your safety some may say.... Thanks for the feedback. I may end up down this or similar path yet anyway.... 1 Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted April 3, 2020 Supporting Member Share Posted April 3, 2020 Hey guys, Has anyone had anything to do with the Yamaha Genuine LED Blinkers Plus - FRONT & REAR YME-FLB2F/R-10? They appear to fill my brief: - Running lights front (white) with integrated amber blinker and Running lights rear (red) with integrated amber blinker and Stop light. These for AU$350 delivered. Still expensive IMHO but just wanted to hear from anyone who has seen them in the flesh and can offer an opinion on how visible they are in the sunlight. Also from anyone who has installed them on an early model Tracer. Any tricks and traps? I currently have el cheapo basic LED blinkers (i.e. el dimmo) and have installed a LED capable third party blinker relay to supply them. Just wondering if the resistors that come with the Yamaha ones described above are needed under those circumstances? At the end of the day, I really don't want to get something that is less than visible and yet pay a lot of money. TIA for any advice. Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted April 3, 2020 Supporting Member Share Posted April 3, 2020 I cant remember who used them but they were happy with them. OEM stuff is usually good they have to meet government regulations for brightness. 1 He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 3, 2020 Supporting Member Share Posted April 3, 2020 @dazzler24 - when you remove the orm lights with the rubber base, you will need an adapter plate to mount the new ones. Yamaha Turn Signal Adapter Spacers for Aftermarket In Hole Stalk Type Indicators These fill the hole left behind when removing the factory turn signals... 1 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted April 3, 2020 Supporting Member Share Posted April 3, 2020 8 hours ago, roadrash83 said: I cant remember who used them but they were happy with them. OEM stuff is usually good they have to meet government regulations for brightness. Thanks @roadrash83 - I did some more searching since posting and found a few positive reviews from those that have them and they do seem to 'do the job'. 7 hours ago, betoney said: @dazzler24 - when you remove the orm lights with the rubber base, you will need an adapter plate to mount the new ones. Yamaha Turn Signal Adapter Spacers for Aftermarket In Hole Stalk Type Indicators These fill the hole left behind when removing the factory turn signals... Thanks @betoney - It looks like the Yamaha kits are quite comprehensive and include everything needed to do the conversion including those adaptor plates. Thanks for the feedback though because it made me look a bit harder at the kit to check. 1 Link to comment Share on other sites More sharing options...
NYTracer Posted February 21, 2021 Share Posted February 21, 2021 Can anyone vouch for the 12oclock labs turn signals? About to pull the trigger on these and would like to know if they are actually as bright as they say. 12oclock Labs Programmable Turn Signals Link to comment Share on other sites More sharing options...
