johnnyparts Posted May 8, 2020 Share Posted May 8, 2020 On 4/25/2020 at 11:22 AM, mingo said: I installed a new Akrapovic exhaust with zero miles on my bike.. I went out for my first ride and got an check engine light, so I checked the O2 sensor and sure enough I didn't plug it in all the way so it disconnected. I reconnected it and now have that fault,, but what I find annoying is now the TFT Menu is blocked. I can't access the TFT menu at all. Is there anyway to access the TFT menu prior to resetting the check engine light? I've ordered a 4 pin to ODB cable and OBD scan tool. Did the same thing with O2 sensor, dropped my pipe to put on lowering links. Had to run the bike a couple minutes after I reconnected the plug before I could clear the code but all good now. Used Autel 309 and some patch wires I made from a wiring diagram from another post here. Link to comment Share on other sites More sharing options...
Wintersdark Posted May 31, 2020 Share Posted May 31, 2020 Has anyone used one of these adapters with a bluetooth ODB2 scanner such as a Scantool scanner, or even one of the little blue Aliexpress/Ebay jobs? Link to comment Share on other sites More sharing options...
