exstowner Posted April 5, 2020 Share Posted April 5, 2020 I just received the kit. I have brake lights working. The running lights flash momentarily when I turn the key on but don't stay on. the turn signals are not working at all. I need help. Thanks for any feedback Link to comment Share on other sites More sharing options...
iamthedruman Posted April 6, 2020 Share Posted April 6, 2020 Hey there, Haven't installed the exact kit you mention but I have installed 2 Admore kits on my last two bikes. They were older models and the instructions were spot on. Did you receive good directions or are you figuring out the wiring as you go? I find the taps they include need to be screwed down as tight as they will go in order to maintain a good connection. Hope this helps. Link to comment Share on other sites More sharing options...
exstowner Posted April 6, 2020 Author Share Posted April 6, 2020 thanks for responding. The instructions are worthless. I am figuring the wiring as i go. I don’t think I have the right wires tapped. I have the yellow wire from the bunch that goes to the brake light tapped right. I have the ground wire that I tapped correct. Just need to figure out the running light and the turn signals. These are the wires I have tapped Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 6, 2020 Supporting Member Share Posted April 6, 2020 13 minutes ago, exstowner said: Just need to figure out the running light and the turn signals. These are the wires I have tapped There is no 'running light' on the rear, or do they recommend just plugging it into a key-on power source like the license plate light? ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
iamthedruman Posted April 6, 2020 Share Posted April 6, 2020 Double check your yellow connection. According to the instructions, the harness-side is as follows: RED*= + 12V (switched); BLUE= Brake Light wire; GREEN= Right Turn Signal wire; YELLOW= Left Turn Signal wire; BLACK= Ground. Here is the wiring schematic from the 2015 FJ-09 (mine) which may or may not be of use to you. It looks as though the connections should be, in order harness to bike: Harness to bike blue to yellow , black to black, red to brown, green to dark green, yellow to dark brown Hope this helps. Link to comment Share on other sites More sharing options...
mingo Posted April 6, 2020 Share Posted April 6, 2020 (edited) I tapped the ground and running light from the license plate light, and the turn signals from the their respective harnesses, and the brake light the blue wire going to the tail light. Everythings works as intended. I'm using an AdMore light bar, but the wiring harness is the same. Edited April 6, 2020 by mingo 1 Link to comment Share on other sites More sharing options...
exstowner Posted April 6, 2020 Author Share Posted April 6, 2020 I used this as my connections: 5 wire harness to motorcycle; BLUE to +12V (switched) (Blue in tail light harness) RED to Brake Light Wire (Yellow in tail light harness) GREEN to Right Turn Signal (Green) YELLOW to Left Turn Signal (Brown) BLACK to ground (Black in the tail light harness) Link to comment Share on other sites More sharing options...
littlebruv Posted April 6, 2020 Share Posted April 6, 2020 I have to be blatantly honest, that tale light looks crap Link to comment Share on other sites More sharing options...
exstowner Posted April 6, 2020 Author Share Posted April 6, 2020 How would you improve it? Link to comment Share on other sites More sharing options...
iamthedruman Posted April 6, 2020 Share Posted April 6, 2020 50 minutes ago, exstowner said: I used this as my connections: 5 wire harness to motorcycle; BLUE to +12V (switched) (Blue in tail light harness) RED to Brake Light Wire (Yellow in tail light harness) GREEN to Right Turn Signal (Green) YELLOW to Left Turn Signal (Brown) BLACK to ground (Black in the tail light harness) Is it working correctly now? Link to comment Share on other sites More sharing options...
exstowner Posted April 6, 2020 Author Share Posted April 6, 2020 No. Based on the chart, it should be. Link to comment Share on other sites More sharing options...
iamthedruman Posted April 6, 2020 Share Posted April 6, 2020 Based on the instructions from the Admore site, it seems like: RED*= + 12V (switched); BLUE= Brake Light wire; GREEN= Right Turn Signal wire; YELLOW= Left Turn Signal wire; BLACK= Ground From your description, it seems like your red and blue are reversed. Link to comment Share on other sites More sharing options...
exstowner Posted April 6, 2020 Author Share Posted April 6, 2020 I looked at the instructions included in the box. You are right. the online documentation is different. I will try it this afternoon. Thanks. Link to comment Share on other sites More sharing options...
exstowner Posted April 6, 2020 Author Share Posted April 6, 2020 Thanks to all. Switched the RED with the BLUE and all working now. Woo Hoo! 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 6, 2020 Supporting Member Share Posted April 6, 2020 49 minutes ago, exstowner said: Thanks to all. Switched the RED with the BLUE and all working now. Woo Hoo! Nice! - Lets see a photo of the finished product with the top box lit up. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
